Question about Amana NDG7800AW Gas Dryer
No heat. Coils should be good as they were
No heat. Coils should be good as they were replaced recently.
  • 547 Answers
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
Nutone 9091 - coils heat up and light works but no heat dispersed.
Open the back, check each little part that has wires going to them for continuity. Theres prob about 6 or 7 of these little fuses and parts. When you find the one that has no continuity, replace it with a new one and you will have heat again.
Jan 24, 2015 | Dryers
LGR5636PQ0 Whirlpool Dryer has no heat
Possibly there's a problem on the coils inside that why it can't suppy the heat to the surface. Even the thermal fuse is ok but the coils supplying never responding to give such heat.
Feb 10, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not heat
The problem with your dryer is bad coils on the gas valve. Replace the coils, Part number: AP2150379
and the dryer should be back to normal.
To get access to the coils you have to remove the front panel.
Good luck.
Jun 15, 2013 | Whirlpool GEW9200L Electric Dryer
My Rheemglass Fury is not putting out much hot water
I believe that there are 2 separate electric heating coils in this unit (unless you are talking about the GAS unit). One of the coils either has a wire broken or the element needs to be replaced!
Dec 31, 2012 | Rheem Water Heaters
Replaced coils / looks good and produced heat but now no heat
caused a short maybe ,reset circuit breaker and check 4 wire against frame
Aug 23, 2009 | GE Dryers
The refrigerator side has stopped cooling.
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 18, 2009 | Refrigerators
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Gas dryer is not heating up
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Nov 06, 2007 | Hotpoint NVL333GY Gas Dryer
Amana NDG7800AW Gas Dryer Logo
61 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
