Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installation problem for windowxp
Dear sir/Madam,
I have vista Home in my laptop this is not supported my software so i plan to change windowxp. If i install the window xp os in my laptop i got the error ( setup did not find any hard disk drives installed in your computer.Make sure and hard disk drives are powered on and properly connected to your computer,and that any disk-related hardware configuration is correct.This may involve running a manufacturer-supplied diagnostic or setup program) so please kindly give the solution to solve the problem
    Problem Solver:
  • 9 Answers
Re: installation problem for windowxp
Pls provide the Hard Disk Controller driver/Sata Controller driver disk at the time of setup. Press F6(to specify sata/scsi controller driver) at the first face of setup and provide the driver floppy disk. I think u can fix the problem by using this solution
Posted on Nov 25, 2007
I had an hp that was not build for nor would it support vista as per HP. I wipe the hard drive using MaxtorBlast4 software. With that you can write 0s to the HDrive. and it will be like a brand new H/Drive. mind you it will take some time. just let it d it's thing. at the end of that, place you vista OS in the CDROM. And be sure that the BIOS is set to boot from CD first. So place you Vista OS in the CDROM and press ctrl-Alt-delete to restart. When the OS is finish installing you would have to go to each manufacture of your hardware site to update you hardware drivers. It will take some time but it will work.
HP want to know how I did it.
Good luck.
Let me know about your progress please
Posted on Nov 17, 2007
  • 37 Answers
Try backing up your important files and format your hard drive and run a clean install of windows xp
  • 100 Answers
You may not have enough space on your hard-drive/s.
0 characters
3 Points
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
This better be god sent. I have a dell desk top at home, 5 yr old. Used it with care. It is vista system based. Tried to install McAfee total protection plan and did not work at all. Uninstalled...
Normally windows vista no problem to communicate with any anti-virus software unless the software is damaged or not supported by windows vista so do not let it work. (If it really can work on vista, most likely operating system you use there is a problem)But do not worry, you still have many choices, for example try to use anti-virus or improve the problem in your operating system.
Hopefully this can help, thank you
Jul 22, 2010 | Operating Systems
Installing AT&T communication manager for data card conflict
Dear sir/madam,
The more you go in to alter settings and programs in your
DELL, them less likely they will be to honor the warranty. Having said that, one
thing you can try IF you have a restoration disk of any kind, is to try to repair
the boot files and sequence. you can use one of two methods. You may get a handy
utility called "VistaBootPro" that does the job very nicely or follow the link below
to MS and run their bootrec scheme. click this link for more information to how to boot to update
windows update.
good luck
Don't forget to rate the solution
Jul 27, 2008 | Microsoft Windows Vista Home Premium with...
Instalation problum
Apr 30, 2008 | Operating Systems
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Conversion to window xp from vista
create a second partition on your hard drive and install xp
format your hard drive and install xp
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
How to install driver in preinstalled vista in notebook OR download xp driver
No vista drivers will not be supported. Recently i did the same thing and ran into troube getting back to vista. Your best bet is to download software updates that are compatible with vista, most things are now. Or if you want to install something if you right click the intall file first and got to properties, then compatibility and change it ro run in xp sp2, apply, ok. see if this helps
Dec 06, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
128 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
