Question about Acer (54.AA806.001) Sound Card
I rebooted my accer computer and the sound card is not working.
My computer is windows xp
Hello; after reinstalling windows xp prof ; no sound is detected
you need to download the driver for the sound card in your system the manufacturers website of the computer should have this for free. if it still doen't detect the sound reboot the computer and enter the bios to see if the card is enabled
Jul 01, 2011 | Computers & Internet
Have sound card but no sound
I recommend you going to control panel under hardware and sound device manager and check to see if your sound drivers are corrupted, if they are unninstall them and reboot your computer, but if they aren't in the list you will have to install your sound card latest drivers my going to the manufacturer website of the sound card and downloading them because without them your sound card will not work
Jun 07, 2010 | Microsoft Windows XP Professional
My firewire suddenly stopped working!!!
I had the same problem after re-installing windows. The firewire just didnt work on the tascam interface. I managed to solve the problem by upgrading from windows xp to windows vista. I downloaded the vista drivers from the tascam site and everything sprang back into action. Problem solved! Hope this helps.
Jul 08, 2009 | Tascam FW-1804 Sound Card
My Dell Inspiron 1521 laptop recently shutdown and would not reboot due to a Windows Vista error. After recovering my files, I decided to install Windows XP. Obvisouly, the product code is not compatabile...
You might find it difficult to get hold of windows XP keys since Microsoft stopped selling it.
If you get on google and search for something called TinyXP (rev09). I think that this willl solve your problem.
May 18, 2009 | Dell Creative AWE64 Value Sound Card
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Hi i formatted my comp lately but i dont hav sound now.
remove the sound card from the Device Manager and reboot. Windows XP or higher SHOULD load the best driver for it
Feb 26, 2009 | Audiovox Jensen NVX-3000PC 7 Windows XP...
My computer has a problem with card sound inside mother board.
Disable the onboard sound car in cmos , then plug in a pci slot fitting sound card, reboot, windows will report new hardware found, load the drivers, restart for changes to take effect, job done.
Nov 16, 2008 | Computers & Internet
Sound disable in xp
Download Windows XP driver for your sound card from the link below :
http://www.drivercabinet.com/windows-xp-realtek-hd-audio-driver-downloads/
install it in your system and reboot your computer for it to take effect.
Hope it's a fixya ... ;)
Nov 07, 2008 | Acer Aspire 4720 Notebook
Sound driver
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP.
Cause:This issue could be caused by any of the below possibilities.
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Solution:Verify software volume control settings
First verify you see a small sound icon sound3.gif in the systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
verify the installed driver settings
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
Conflicts section
If conflicts exists with your sound card and/or other devices installed in your computer it is likely that either the drivers are not properly installed for that device and/or the sound card and/or other devices are conflicting. If you open the properties of the device that is conflicting and view the properties, additional details about the conflict can be found. Additional information about error codes as well as help with Device Manager can be found on our Device Manager section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Other devices section
If other devices are listed, it is possible that these other devices could be the sound card or other devices conflicting with the sound card. If any other devices are listed it is recommended you remove those devices, reboot the computer and let Windows redetect the devices.
If this does not work, attempt to determine which device is not being detected and resolve that issue first.
Missing sound card section.
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
If this is an on-board sound card you can verify that it is enabled in BIOS setup. Additional information on entering the BIOS setup can be found on document CH000192.
If you have no adapters and/or cannot click the down arrow to select the correct adapter, close out of this Window. In Control Panel double-click the System icon / click the Device Manager tab within Device Manager and ensure there are no yellow ! or red X.
If you have either of these on any of your sound devices, attempt to remove everything under Sound Video game controllers and reboot the computer. If after rebooting the computer you still have the same conflicts, double-click on the conflicting device and refer to our Device Manager error code section giving you additional information on the error code you are experiencing.
Verify speaker connections
Verify the speakers settings and speakers are not at fault by running through speaker troubleshooting steps in document CH000034.
Sound card drivers
If you have followed the above recommendations and you are still unable to get the sound card to work, download and install the latest sound card drivers from the computer or sound card manufacturer. A listing of sound card drivers can be found on our sound card driver page.
Dec 26, 2007 | Toshiba Satellite U205 Notebook
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
