Question about Nintendo DS Lite Console
Nds lite does not turn on no green light, amber light comes on with charger, have checked fuses with circuit tester seem OK no obvious signs of corrosion or damage.
  • 88 Answers
Posiible L2 inductor fault
see http://dsdoctor.co.uk
Posted on Aug 13, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
NDS Lite still red light
well one thing that can cause this is major damage in the charger or the ds lite
Feb 02, 2010 | Nintendo Video Game Consoles & Games
NDS LITE WILL NOT TURN ON
send it to the nintendo people
Jun 21, 2009 | Nintendo DS Lite Console
NDS Lite Green Lite flashes but does not turn on!
it thinks that its still closed try turning it upside down and shaking it
Apr 06, 2009 | Nintendo DS Lite
DS Lite will not power on
blowin F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (symptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Mar 28, 2009 | Nintendo DS Lite Console
Ds lite not working
i had same problem ( bought a faulty nds off ebay and would charge but nothing when powering up, not even a blink of green light) problem is a component called a L2 its an inductor 33uH in case SMD 1007. its situated dirrectly under the power switch but they are prone to fall off when nds is dropped ect. you need to resolder it on (very tricky). give your nds a shake to see if you can hear it rattelling about. be carefull when opening your nds not to lose the part (its very small, about 4mm long 2mm wide) GOOD LUCK
Jan 05, 2009 | Nintendo DS Lite Console
Nds lite wont turn on
There maybe something wrong with the jack inside your Nintendo DS, you can easily get them repaired at a few shops, just tell them that the On/Off switch doesn't turn the DS on and they'll fix it for you, shouldn't cost an awful lot as they're just replacing something inside.
Oct 10, 2008 | Nintendo DS Lite Console
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Jan 23, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
262 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
