Question about Boss Micro BR Digital Recorder
C.d burner has stopped working on my BR1180
The burner has quit working. It will play a c.d but not write. The window says ' C.D read error" If I hook it up to a P.C with the RCA cable into the Boss output and the other end into the mic input on the computer will I be able to burn a c.d from that still?
    President:
  • 1,138 Answers
As long as it indicates program content in the memory and can play the audio through an am p or headphones you should still be able to record the content onto your computer and burn it from there if your computer has a burner. I use Audacity which is a good freeware program.
Posted on Jul 24, 2009
Peavey sp2 pa speakers quit working
Ok,
First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
Feb 03, 2013 | Peavey SP2 PA Passive Speaker
How to ready the cd to burn music from br1180
They have some updates, if you have not run the update, that may solve the issue.
http://www.boss.info/global/support/downloads_updates/
http://www.bosscorp.co.jp/en/index.html
Apr 01, 2012 | Music
Br1180 disk not ready
They have updates. Plus manuals if you do not have the manual.
Can the write speed of the internal cd burner be changed on the tascam 2488 mk ii to produce a more accurate audio cd . if not how is the write speed determined .thanks Andy
The actual disc speed in the unit has nothing to do with the speed that a CD plays back.
Read page 68 of your user manual for variable speed and pitch setup and changing.
May 24, 2011 | Tascam 2488mkii 24 Track Recording...
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Connection problem
simple bro. . .. flick the korg kaoss pads setting to send . . u will find this on the back. . . i thin you have it set to direct. . flick it over to send and then let em know if it works. . . and could u answer ASAP what cords you used to connect the kp3 to the send return on your mixer. . .thanx
Dj Nap
Dec 24, 2008 | Korg Mini Kp Kaoss Pad
Boss Micro BR Digital Recorder Logo
121 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
