Question about Cisco 7960 IP Phone
Message Indicator light displayed when there is no message
With services hosing up this morning (global directory not available and unable to cancel call forwarding) we restarted the server. Once the server came back up several users had a message indicator light but no voicemail messages. I have not been able to find a way to reset this.
    Problem Solver:
  • 5 Answers
Don't know if you configured your CM server or not but there are two numbers that control the MWI. One number activates the lamp and the other turns it off. This is configured when you configure the system so I can't tell you what your numbers are. If you're using CM and not CME it's under the voice mail tab. Simply dial the number that turns the lamp off from the phones in question.
Oh and next time if you have an issue try restarting the CM service first instead of rebooting the box.
Posted on Aug 01, 2009
Message light blinking but no messages.
That might be the Voice Mail Waiting Indicator which works
with the telephone service provider's 'VoiceMail' feature.
On the D1680 and similar handsets, it can be reset by:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if needed.
Apr 21, 2015 | Uniden Cordless Phone
2wd vs AWD
Page 13 of owner's manual says:
AdvanceTrac
(if equipped):
Illuminates when the AdvanceTrac
system is active. If the light remains
on, have the system serviced
immediately.
AWD locked (if equipped):
AWD
Illuminates when all wheel drive
LOCKED
(AWD) is engaged/activated. If the
light continues to flash, have the
system serviced.
Page 224:
ALL WHEEL DRIVE (AWD) SYSTEM (IF EQUIPPED)
Your vehicle may be equipped with an All Wheel Drive (AWD) transfer
case. With the AWD option, power is supplied to all four wheels
automatically with no need to shift between two-wheel drive and
four-wheel drive. If your vehicle is equipped with the AdvanceTrac
stability enhancement feature, you can change AWD modes, if desired,
by selecting AWD options through the message center.
For the lubricant specification and refill capacity of the AWD transfer
case refer to Maintenance and specifications chapter.
If your vehicle is equipped with AWD, a spare tire of a different
diameter than the road tires should never be used. Such a tire
could make the vehicle difficult to control as well as result in damage
to driveline components.
Utility and four-wheel drive vehicles are not designed for
cornering at speeds as high as passenger cars any more than
low-slung sports cars are designed to perform satisfactorily under
off-road conditions. Avoid sharp turns or abrupt maneuvers in these
vehicles.
The following sections, Normal operation, Autolock operation and
Disabling AWD, apply only to vehicles which allow the driver to change
AWD modes through the message center.
Normal operation (vehicles equipped with AdvanceTrac
During normal operation:
• the AWD system is in AWD AUTO mode (AWD LOCKED will
illuminate in the message center for four seconds when you first start
your vehicle). The AWD LOCKED indicator in the instrument cluster
will also come on.
• AWD AUTO mode can be overridden by pressing SETUP in the
message center. When you first press SETUP, AWD <AUTO> will be
displayed, then if you press RESET within four seconds of pressing
SETUP, AWD <LOCKED> will be displayed. AWD <LOCKED> provides
power to all four wheels constantly which allows you to operate your
vehicle in severe winter or off-road conditions such as deep snow, ice
or shallow sand. It is not recommended that you use AWD <LOCKED>
on dry pavement.
Page 225:
• AWD <LOCKED> can be cancelled by pressing RESET in the message
center. (The AWD LOCKED display in the message center will then
turn off and the display will return to AWD <AUTO> for four seconds
when the shift is complete.)
Autolock operation (vehicles equipped with AdvanceTrac
If the AWD system begins to overheat, the system will place itself in the
Autolock mode:
• the AWD LOCKED indicator light will illuminate in the instrument
cluster and AWD DISABLED <LOCKED> will be displayed in the
message center.
• AWD LOCKED will be displayed in the message center for four
seconds and a warning chime will sound. This condition may clear
without any action being taken by the driver.
• the AWD LOCKED indicator light in the instrument cluster will turn
off when the AWD system cools down.
• When the system is sufficiently cooled down, AWD AUTO RESTORED
will appear in the message center for four seconds and a warning
chime will sound.
Disabling AWD (vehicles equipped with AdvanceTrac
When a problem is detected in the AWD system:
• the AWD LOCKED indicator light in the instrument cluster will flash
eight times every two minutes in the message center.
• The message center will then display AWD DISABLED for four
seconds, then SEE OWNER'S MANUAL. A warning chime will also
sound. The warning displays and chime will continue until RESET is
pressed (which will clear the message from the display).
• AWD LOCKED can still be engaged by pressing SETUP (the message
center will display AWD <DISABLED> LOCKED), then pressing
RESET. The AWD LOCKED indicator light will illuminate in the
instrument cluster and the message center will display AWD
DISABLED <LOCKED>.
• To disable AWD, press RESET. The system will go back to AWD AUTO
mode momentarily, then the AWD LOCKED indicator light will flash in
the instrument cluster eight times every two minutes. The display will
then show AWD <DISABLED> LOCKED for four seconds and then
turn off.
Page 226:
• If a serious problem occurs with the AWD system, the AWD LOCKED
indicator light in the instrument cluster will flash 10 times every two
minutes. The message center will also display CHECK AWD and a
warning chime will sound. You can press SETUP to check the status of
the AWD system (which will display AWD <DISABLED> LOCKED),
but the AWD system will be disabled until the system is serviced.
Driving off-road with truck and utility vehicles
AWD vehicles are specially equipped for driving on sand, snow, mud and
rough terrain and have operating characteristics that are somewhat
different from conventional vehicles, both on and off the road.
When driving at slow speeds off-road under high outside temperatures,
use 1 (First) gear when possible. 1 (First) gear operation will maximize
the engine and transmission cooling capability.
Under severe operating conditions, the A/C may cycle on and off to
protect overheating of the engine.
Nov 30, 2013 | Lincoln Navigator Cars & Trucks
Display Message
This only shows on the operator extension. It is there to notify you that a Night or Evening or some other service is turned on. You can press the LIST soft key to find out which service is in effect. You can cancel the service, but then you also cancel the purpose of the service like night ringing or directing some lines straight to voice mail. Feature #871 will cancel ringing service, #872 will cancel restrictions service, and #873 will cancel routing services.
Jun 11, 2013 | NorStar M7208 Corded Phone
Message light blinking but no message there cannot remove message light
you have to log in to your account at the phone service provider and reset message waiting indicator. If you have a contract company managing your ip phone service, call them, and say you need the message indicator reset.
Mar 07, 2013 | Mitel 5330 IP Phone
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
Since changing to ACN, I get no blinking red light alerting me that we have a message.
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Apr 12, 2011 | AT&T TL74108 5.8 GHz Quad 1-Line Corded /...
Hi, i can no longer use my canon ip1980, the error message " ink absorber full, contact your service provider" how can i fixed my printer? thanks
1. Turn off the canon printer.
2. Hold button Resume/Cancel (red triangle in the circle), click on POWER - an indicator light green.
3. Release the button Resume / Cancel keeping POWER.
4. Click Resume/Cancel 2 times, keeping POWER, and then release all the buttons.
5. When the indicator recorded GREEN - click Resume / Cancel 4 times!
6. Turn off the printer POWER button.
7. FINISH
i hope this helpful
thank you for using fixya
Mar 16, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Voicemail MSG indicator, but no message
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s theat left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Sep 10, 2009 | NorStar M7310 Corded Phone
" Active Directory is rebuilding Indices please wait"
Go in eventvwr - start>run>eventvwr and check the Directory Services event
log in particular. This message you're getting could mean a number of things.
Jan 03, 2009 | Microsoft Windows Server Standard 2003 for...
EVIC - PERFORM SERVICE MESSAGE
To reset the perform service message , is as follows , turn ignition switch to the ON position , depress and release MENU push button until SERVICE INTV . = is displayed , press and release STEP button to step through available options. the last selected distance option displayed becomes the service interval at which the PERFORM SERVICE message will be displayed . if a new distance interval is selected , RESET SERVICE DISTANCE ? with a yes or no option. when yes is selected the accumulated distance since the last previous PERFORM SERVICE message will be set to zero because the service interval has been changed . when NO is selected , the distance until the next PERFORM SERVICE message is reduced by the accumulated distance since the last previous message . EVIC exits programming mode and returns to its normal operation mode when the C/T button is depressed or when the end of the programmable feature menu list is reached , whichever comes first .
Thanks for asking .
Dec 30, 2008 | 2002 Jeep Grand Cherokee
Cisco 7960 IP Phone Logo
1,751 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
