Televison & Video Logo
P
Pat Romeo Posted on Dec 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
The green lines fade in and out covering all to just a portion of the affected area of the screen. This happens on all inputs and after unplugging the set for 2 minutes. Is this problem economically fixable? I assune it is a control board. Can I purchase it and install it myself? Thanks, Pat
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 16, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066274
Points
28436
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
What's wrong with my Bravia if at power up screen displays vertical thin lines with dark background. Power LED is green. Thanks Guys!!
This sounds like the power supply in the TV. It may be a bad capacitor or a bridge rectifier causing the problem. Get a volt meter and start making some voltage measurements. This may help find your problem.
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
21helpful
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
4helpful
2answers
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
