Question about Emerson Quiet Kool 10GV13 Air Conditioner
There is no carbon filter attached to the window air conditioner. Was there one originally?
  • 158 Answers
There must be another type usually a thin hard plastic layer mesh type inserted in front
Posted on Jul 14, 2009
Where can i buy filters
Amcor was bought out, and no longer supports this product or provides replacement parts for it. The unit has two filters:
  • Washable air filter which collects large dust particles and prevents bacteria build-up
  • An activated carbon filter to help remove odor
There is no manufacturer of filters (carbon or air) for this product, however if it were in my possession I would remove the carbon filter and take it into my local Home Depot or Lowes ( or whatever you have in your neighborhood) and see if they have something that might fit that is similar. Many filters work in more than one brand. The air filter should be washable still, if it is damaged you can probably do the same thing I suggested with the carbon filter.
May 01, 2014 | Amcor AL10000E Air Conditioner
Hi, I have a Friedrich air conditioner. Old one I am pretty sure. Maybe 9 years. Model is SL28J30A-D. I have a feeling my filter is not working properly or I don't even have the right one in. Currently I...
The evaporator coil (cold coil) would freeze up if the air entering is restricted. It could shut down because the rear coil (condenser coil) is dirty or obstructed. Sometimes there's debris or even bird's nest blocking the condenser air outlet, this causes heat and high head pressure.
Aug 27, 2013 | Friedrich Heating & Cooling
The check filter light will not go off even after I have cleaned the filter numerous times; and now occasionally the unit wil rapidly shut it self on and off repeatedly (again the check filter light is...
Apparently, the unit is not recognizing the filter change. So, turn the Master ON/OFF Switch to OFF and unplug the unit. Wait 15 minutes and plug it back in. Turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset themselves and reverted back to the original factory settings and the change filter light is now, OFF.
Hope this helps you.
Jul 08, 2011 | Frigidaire FAH106N1 Wall/Window Air...
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Do rv roof air conditioners have a filter? if so where? the trailer is a yellowstone cirrus/87. thanks rm
Your ceiling assembly should have filters attached to it, that can be removed and cleaned.
May 25, 2010 | Dometic Rooftop RV Air Conditioner
How do you fix seal leak on dometic rooftop air conditioner ?
remove filter etc. from ceiling assy, you'll see 4 bolts that you remove,(basically 4 corners of lower tray at ceiling) unplug wiring harness and connector, that goes to upper unit from lower, then lift upper unit up off roof. position upper unit to allow for removal of 14" gasket. Install new gasket, set upper unit back over hole align properly, and re-install 4 bolts. Snug evenly until gasket is approx. half thickness of original. Re-attach harness plug etc.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
My Rinnai says not to use it without an air filter and to clean the air filter once a week--but I can't see an air filter. Is it possible that it was installed without one?
If you have a RHFE263, 431 or 556, the air filter is located at the top in the seam where the wall trim piece attaches to the heater. It looks like a dryer lint filter.
Feb 15, 2010 | Rinnai EnergySaver 556 Air Conditioner
Question about model #253-355080
I woud suggest putting a pan under the unit with a hole in it that you can attach a hose bib and then attach the hose to it and run the hose to a better location...
Jun 19, 2007 | Kenmore 72175 Air Conditioner
Emerson Quiet Kool 10GV13 Air Conditioner Logo
59 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
