Question about Mitsubishi Heating & Cooling
A MITSUBISHI MODEL FDKN204HEN SHOWS ''UOOOE32'' ON THE SCREEN
Mitsubishi Heavy Industries, model FDKN204HEN shows ''U000E32'' on the screen and red light blinks on the run/check and the unit does not work. Can anyone tell me what this is. Thank you very much
4 Suggested Answers
  • 15 Answers
SOURCE: mitsubishi heavy industries a\c srk20zcx-s
Most of the time once every season so once a year same time you clean the filters. But being thats its the cheaper chinese made heavy industries and not the better quality japanese made mitsubishi electric i would say once every 3-6 months
Posted on Mar 16, 2008
  • 7 Answers
SOURCE: Mitsubishi electric or Mitsubishi Heavy Industries
as an refrigeration engineer dealing whit them every day my advise is: mitsi heavy industry away much more reliable and better performing.
Posted on Jun 27, 2009
  • 534 Answers
SOURCE: No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Posted on Jan 12, 2010
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Outside unit do not run.Red light blink 6
That is a trouble code signalling that your unit needs service. It is time to call a professional for help!
Jul 13, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Looking for a downloadable user manual for a Mitsubishi Daiya wall mounted split air conditioner the model is FDKN204HEN.
Not sure if you are still logged on to this post but I have a manual. Trying to locate a new remote for this model!! I can email you the owners manual?
Jun 29, 2010 | Kitchen Ranges
Jan 29, 2009 | Mitsubishi MS15TN Air Conditioner
Mitsubishi heavy industries a\c srk20zcx-s
Mar 06, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
211 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
