Question about Dell HK395 Computer Speakers
HK 395 Speaker jack works intermittiently
Is there anywhere you can buy the 1/8" female jack (green color) on the back of the woofer (it's a 5 pin jack that solders on the circuit board?
    Problem Solver:
  • 16 Answers
Any Radio Shack
Posted on Jul 15, 2009
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    Internal wiring schematic for a JBL 4311 WX-A
    the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
    1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
    2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
    And connect the tweeter at the empty output
    Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
    Feb 16, 2010 | Audio Players & Recorders
    I Do Not Know How To Connect Boston Micromedia To My Computer
    The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
    1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
    .) Connect the cable sets to the back of the two small speakers along with the speaker feet.
    Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
    2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
    (a) White cable end (left speaker) to white jack on sub-woofer.
    (b) Red cable end (right speaker) to red jack
    (c) Purple cable end (input) to the purple jack
    (d) Green cable end (computer out) to the computer's microphone output jack.
    Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
    3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
    A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
    May 17, 2009 | Boston Acoustics MicroMedia Computer...
    Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
    The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
    Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
    Broken Female audio plug
    take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
    Nov 05, 2008 | Onkyo Audio Players & Recorders
    HOW TO CONNECT CREATIVE INSPIRE 4.1 OR 5.1 SPEAKERS WITH A HP COMPAQ 6720s LAPTOP
    HI I BOUGHT CREATIVE M4500 4.1CHANNEL SPEAKERS I UNABLE TO HEAR SUND FRONM THE 4 I CAN HEAR FRM THE 2 SPEAKERS PLZ HELP ME IS IT A DRIVER PROBLEM OR....
    Aug 03, 2008 | Creative Labs Sound Blaster Live! 5.1...
    Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
    Hi rjlevesque
    For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
    Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
    I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
    Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
    You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
    Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
    green = speakers
    pink = mic
    blue = line in
    Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
    If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
    If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
    If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
    If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
    Please, let us know if this response was helpful for you or, of course, if you have any further questions.
    Thank you
    BJ
    Apr 03, 2008 | Computers & Internet
    Need wiring and 9pin connector diagram
    Dell (Altec Lansing) A425 Subwoofer Pinouts
    This is a standard female DB-9 serial port.
    Here are the pinouts.
    Pin 1 = Left Speaker Out +
    Pin 2 = Left Speaker Out - (Common Ground)
    Pin 3 = Left Line In +
    Pin 4 = Right Line In +
    Pin 5 = Left/Right line In - (Common Ground)
    Pin 6 = Right Speaker Out +
    Pin 7 = Right Speaker Out - (Common Ground)
    Pin 8 = Power A
    Pin 9 = Power B
    Jumper (short) Power A to B to turn on.
    If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
    Here is some info on how to do this.
    http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
    Cheers!
    Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
    Creative 5 in 1 speaker set up
    buy jack to connect all the cables.
    because computer are only two output audio terminal.
    Oct 14, 2007 | Creative Labs FPS2000 Computer Speakers
    Dell HK395 Computer Speakers Logo
    271 people viewed this question
    Top Dell Audio Players & Recorders Experts
    jairo sanchez
    Jax Planet
    Jax Planet
    Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
