Question about HP Scanjet 5490c Flatbed Scanner
Scanning light, power light, toggle light are all blinking
HP Scanjet 5490c - I was scanning and the light stopped midway in the scan. Now the scanning light, the power light and the toggle light (b/w versus color) blink in unison. I have disconnected the power cord and the USB connection and reconnected them but nothing helps. I have rebooted my computer to try to trigger the lamp to move/reset but it doesn't work because the computer doesn't recognize that the scanner is attached. There is nothing on the LCD. I can't do a reset or anything because the scanner isn't recognized.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Posted on Jun 14, 2007
rdavidd
SOURCE: Scanner stopped in the middle of a scan
Although I can not be sure without testing it, the most common problem with this type of issue is that the power supply adapter has failed. According to the manual (posted at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00215714/c00215714.pdf) this scanner has an external power adapter. Since you indicate that the scanners light does not come on, I would be inclined to believe that power adapter needs to be replaced. However, before you go and buy a new one, I would suggest you get the current adapter tested with a volt meter to determine if it is outputting the correct voltage and amperage.
If you discover that the power adapter has failed, you may be able to simply replace it in order to get the scanner up and running again. However please take note that depending on what part of the adapter circuit failed, its failure could possible have also damaged the scanner's internal circuits. However, if you find after testing that the adapter is outputting the correct voltage and amperage, then the problem would most likely be a scanner board circuitry failure.
Posted on May 04, 2009
AldRezaine
  • 995 Answers
SOURCE: ARE THERE REPLACEMENT bulbs for an hp scanjet
Yes it has a replacement. Try to find it in some computer stores.
Posted on Oct 30, 2009
SOURCE: I have a HP scanjet 2400. It does not scan
scanner clean miror & roll with oild
from haresh patel
Posted on Dec 25, 2009
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
My hp scanjet G2410 makes a cracking noise when scanning
A jammed or broken tooth on a gear will cause cracking sound. And will continue until you shut off power. The reason the sound continues is because it's still in the process of scanning and hasn't reached the white tape which the sensor senses to return to the finished position. An HP scanjet just as its printers don't have a sensor to stop the carriage from moving until the job is completed. Further use will ultimately cause a loud pop and cause further damage.
Jun 12, 2012 | HP Office Equipment & Supplies
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
HP 5200c scanjet - get black page
yes, your fluorescent bulb is burned out and you cannot buy a spare. Sorry
Oct 11, 2009 | HP Scanjet 5200c Flatbed Scanner
Hp scanjet G2710 scanner isnt scanning the whole document.the light only moves half way then stops
If you are scanning via software then the software could be looking for a smaller image. Check the preview and adjust the size as necessary.
Apr 30, 2009 | Office Equipment & Supplies
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Problem with scanning of document
just try once by reloading the drivers and try with another usb port and cable, if the problem is not solved then your scanner needs servicing
Dec 23, 2008 | HP Scanjet 5590 Flatbed Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
Belt
You dont say where you are so it is not possible to tell you where to look.
Likely as not as with most small electronics these days no parts are available - service by replacement is the name of the game,
You could try HP support I guess
Mar 21, 2008 | HP Scanjet 5470c Flatbed Scanner
HP Scanjet 5490c Flatbed Scanner Logo
361 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
