Question about ASUS A6Km Notebook
Asus A6Km, only powers up for 3 seconds
I have an Asus A6Km, and it only powers up for 3 seconds, then off.
I've taken out DVD, hard disk, RAM and Wifi board. Still does the same thing. I've even disconnected LCD. Same.
  • emilioea Jul 14, 2009
    thught about that too... not working. Fan works OK, ive tested it with a DC power supply ans oscilloscope. Has anyone had this problem?
  • 66 Answers
- check the Fan. sometimes if the Fan is not working or has some obstruction making it to revolve slowly then it powers-off like this.
- if fan is perfect in those 3 mins, then get your power adaptor checked and also the power section of the laptop.
Posted on Jul 14, 2009
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
My laptop asus a6km won't start. instead all the lights flashes some time and blink and trn off that's all
Unplug computer first then remove your battery. After removing the battery press and hold down the shutoff button for a full 60 seconds. This should discharge any static electricity in the system. Replace battery then plug back in. Perform these steps in the given order. If this does not work then you will most likely need to have service performed on your system.
Feb 16, 2011 | ASUS A6Km Notebook
My asus laptop wont power up , the green light flash for about 3 seconds and thats it
This might do the trick:
  1. Remove the AC adapter, Battery and all other power sources
  2. Press the power button for 20 a 30 seconds. (Bios is now resetted)
  3. Put everything back in and try to boot;).
Dec 21, 2010 | ASUS A6Km Notebook
My computer restars while nfs shift on max settings games config : 9600gt, asus p5k, 4 gb ram, 3 500gb hd, 1 sata lg cd dvd burner
Hi, if your computer restarts this means that your computer lacks of power..you a running 3 hard disks drives ?? + 4 dvd writer ..try to unplug a hard disk the dvd drive and unused usb devices and see if your computer can handle playing on maxed out setting if yes then upgrade your power supply unit for a 550w ;) enjoy
Jan 17, 2010 | ASUS Computers & Internet
Hi there, i have a problem with my motherboard. I bouth it second hand with P4 CPU and Power suply, when i plug it into my computer it reads the hdd and dvd-rom and thats it, staing like this all day. When...
Check The RAM ( Memory )
also that the DVD And Hard-Drive jumper settings, are correct. i.e Hard-Disk set As Slave. DVD/CD ROM SET As Master ( if on the same IDE Connector/Cable ) Also insert your operating system Disk, In The CD?DVD Drive.
Mike @ Compurepair.
Nov 04, 2009 | ASUS P5S800-VM Motherboard
Computer will not start. screen has blue vertical bands
Dear there are three possibilities
1- Ram Problem
2- Ram Slot Problem
3- Hard Disk Power Plug
So change your ram or slot if problem will presist then you should change your Power Plug cable. Fix your power plug of your hard disk properly.
Good Luck
Aug 21, 2009 | Dell 16X Internal DVD-ROM Drive for...
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
Comes on only for 3 seconds
Try taking out the DVD RW drive and see what results you get then?
Mar 31, 2009 | ASUS A6Km Notebook
Hi, I ve just put a desk top computer together and nothing is happening i get no sound out ie no beeps and the screen is not coming on. the manual refers to jumper cable i can not locate them. The...
DEAR,
1.CHECK POWER SUPPLY(VOLTAGE)(+12,+5) COMING OR NOT COMING.
2. YOUR RAM (GIVEN DISPLAY OR NOT)CHECK WITH ANOTHER COMPUTER.
3.CHECK YOUR MOTHERBOARD,PROCESSOR GIVEN DISPLAY OR NOT(ALTERNET CHECK MOTHERBOARD OR PROCESSOR WITH ANOTHER COMPUTER)
CAUTION:---1.WHEN THIS TYPE OF CHECKING OF HARDWARE KINDLY REMOVE YOUR HARD DISK DRIVE POWER CABLE FOR.
2. ELECTRIC EARTHING IS PROPERLY REQUIRED.
Feb 25, 2009 | ASUS P4S533-MX Motherboard
ASUS A6Km Notebook Logo
740 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
