Question about Yahoo Messenger
Login error 81003004 from Yahoo Messenger" - Yahoo Messenger
weblord
  • 507 Answers
SOURCE: Problem signing into Yahoo Messenger.
uninstall yahoo messenger completely and download a fresh one, re install fully, if still has errors, contact ym http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Posted on Nov 20, 2008
SOURCE: Error 81003004
Go to this web page link and follow the directions
http://www.error-repair-tools.com/ppc/error.php?t=81003004&gclid=CJDm_aKP4pkCFQw9GgodVFiLVw
Posted on Apr 08, 2009
  • 32 Answers
SOURCE: login error 81003004 from Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Posted on Jun 02, 2009
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
  • 79 Answers
SOURCE: Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Posted on Jun 08, 2009
When i login to yahoo messenger a messege displayed 81003004
This error code is displayed if the registry entry has some invalid entry
Go to start > Run > "regedit"
try deleting the reg key:
"HKEY_CURRENT_USER\Software\Yahoo\pager" and exit messenger and login.
Jan 15, 2010 | Yahoo Computers & Internet
It has already solved. Refer to :-
http://www.fixya.com/support/t1385966-login_error_81003004_from_yahoo
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 19, 2009 | Yahoo Messenger
Error no.81003004, i'm unable to access my ym, plz help asap
It is some update problem. Were firewall settings blocked ym from opening and connecting. Try this methods....
Read this link
http://www.fixya.com/support/t2536484-81003004
Aug 23, 2009 | Yahoo Messenger
I get error as 81003004 while login
Here is a site that show's you how to set up an HTTP Proxy server in Yahoo Messenger which should fix the problem:
http://www.theanand.com/blog/index.php/techie/81003004-yahoo-messenger-login-error/
and here is the site where you can find a LOT of good proxy servers to use:
http://www.proxy-list.net/fresh-proxy-lists.shtml
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
thank you
Jun 02, 2009 | Yahoo Messenger
Error message 81003004
try this solution
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Yahoo Messenger Logo
308 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
