My HL 2040 How do I print an address on an
My HL 2040 How do I print an address on an envelope?
    President:
  • 2,306 Answers
You have to select envelope size in your word program, and then place envelopes one at a time in the slot in the front door.
Posted on Jul 14, 2009
How to print a single #10 envelope with Brother
PLEASE READ THIS and use it as a guide http://www.ehow.com/how_6039123_print-envelopes-brother-mfc_685cw.html
Mar 22, 2010 | Brother HL-2040 Laser Printer
Print envelopes brother 2040
Ummm... Just go to the user manual. It will show you how to do this. It's really not hard. Manually feed the envelope into the printer (that thing on the front that you can play with and the sides get closer, and further apart at the same time) You'll need to have word set to print on an envelope. Again not hard just a little bit of know how. Google "word envelope print" and you will find instructions on how to set up word.
Sep 23, 2009 | Brother HL-2040 Laser Printer
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
Lost an envelope in the printer
At first I couldn't get the inker cartridge out, to look for the envelope but with more trying, I was able to remove it and I saw the envelope, which I could easily pull out.
Apr 09, 2009 | Brother HL-2040 Laser Printer
Connect to network printer
Are you positive it is a HL 2040? The 2040 only has parallel and usb ports. The HL 2070 has the network port.
Anyway, if it is already being printed to on the network from other printers go to one of the other PC's and look under the printer properties tab, go to the ports tab and see which IP address has a checkmark in the box......that is the IP address you will need...
If it isn't already setup on another PC then you will need the setup CD that has the BRAdmin Professional Software.
Jan 16, 2009 | Brother HL-2040 Laser Printer
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
Brother 2040 printing watermark
does the printer do it from beginning? or after cartridge change?
Apr 11, 2008 | Brother HL-2040 Laser Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER IF YOUR DARING.)
Jan 29, 2008 | Brother HL-2040 Laser Printer
116 people viewed this question
k24674
