Question about Garden
Leak gas line
How to replace fuel line on Ryobi 775r trimmer. No fuel line from tank . Missing.
  • 512 Answers
SOURCE: Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Posted on Jul 17, 2009
SOURCE: Ryobi 700r gas trimmer. Leaking fuel from the fuel
There is no nipple. The fuel line is just pushed through and holds itself tight against the hole in the tank.
This is the return line from the primer bulb, right?
Just replace the line and you should be fine. I think that some of these Ryobi lines are 3/16 OD and 3/32 ID, but I just picked up a Ryobi fuel line kit at Home Depot today, and the black line seems to fit nicely here. (My trimmer still won't start, but at least it doesn't leak gas any more.) Be careful to note which line comes from where on the orimer bulb.
Steve
Posted on Jun 01, 2010
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
elix0411
  • 3530 Answers
SOURCE: My Ryobi gas trimmer is
If the hose is loose on the nipple try a small hose clamp to fix it. As long as there is no crack outside it, your tank is ok.
Or you can replace the return line. I believe this is a known issue for some Ryobi models.
Be careful to note which line comes from where on the primer bulb.
Posted on Oct 07, 2010
rycgl
  • 1545 Answers
SOURCE: i need the fuel/oil mixture
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Jan 11, 2011
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
Replacing fuel line on ryobi 775r trimmer. when i removed old line and filter, the plastic fitting with the filter protruded about 1/4'' out of tank and was held by plastic retainer ring, now i can get the...
First off, get a piece of fuel line longer than you need for the job. With the gas tank removed, wrapped in a towel and put in a vice to steady it I fed the gas line in from the outside of the tank to through the fuel hole (where the gas cap fits on). I carefully worked the fuel line onto the filter until it was all the way on (touching the bottom of the filter assembly). I then gently pulled on the line feeding it through the hole. Then with gentle pulling, twisting and nudging from inside and outside the tank I worked the fuel filter nipple through the hole on the bottom of the tank until it was flush and secure.. Once the filter and fuel line were secure in the hole on the bottom of the tank, I then worked the secure ring up the fuel line and worked it onto the filter stem until it was snug. I then fed the line through the appropiate holes in the engine, trimmed it to size and fitted it on the nipple on the engine.
Jul 03, 2010 | Ryobi Garden
Ryobi 700r gas trimmer. Leaking fuel from the fuel return line...what is the best way to fix this?...seems to be leaking where the tube goes up into the fuel tank. thanks.
Steve
May 12, 2010 | Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
Jul 17, 2009 | Garden
RUNS AND STALL WHEN YOU GIVE IT GAS
you are right on. try richer mixture.
May 22, 2009 | Ryobi Garden
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
