Question about Canon P27-DH 12 Digit Mini Desktop Printing Calculator
On screen show E and can not print or .How to remove
Calculator not working shows E on left side and I want to know how I can fix it.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Your calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Posted on Feb 02, 2016
SOURCE:
The calculator is frozen (no keys will work) A number 4 shows on the screen and a "C" prints out
Try removing the batteries and unplugging from power supply. Then replace batteries/reconnect. That may restart the unit.
Oct 14, 2015 | Canon P170-DH Calculator
Display shows E
In my case, the screen showed an 'E' lower left of screen, and the 'Print' and '5/4' at the top of the screen. I pressed the D/# key (just below 5/4 key) and then pressed the P/NP key (not sure if I pressed them at the same time). Also pressed the D/# key and 5/4 key.
Hope this helps.
Sep 19, 2013 | Texas Instruments TI-5006 II Calculator
When I turn on my calculator, 1/3 of the screen is blank. When I enter numbers, they show up after the blank side. Basically, the left side of my screen stopped working, and it has nothing to do with...
The problem is in one of driver ic's that controls the LCD display is malfunctioning, the only way to correct the problem is replace the ic, this will require a technician.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
My calculator shows 0.00000000 instead of 0 every time. How should I fix it? All the functions works properly, but there are too many zeros for me.
At the top left of the calculator, you will see a sliding switch that is labeled: DECIMAL A,0,2,4,6,F. Move the indicator to the "0". This will remove all excess zeros. The numbers represent how many decimal places the screen will show. I have the manual for this calculator if you need it. LBrown18062@hotmail.com
Jan 03, 2011 | Citizen CX80 Scientific Calculator
Calculator is frozen
re-boot the calculator remove all batteries and if that does not work then you should consider a new calculator. GOOD LUCK
Sep 21, 2009 | Texas Instruments TI-84 Plus Calculator
When I turn on my ti 83 plus, I only get a blinking bar on the top left. None of the buttons work, and it says RAM cleared. How do I fix?
RAM cleared means that the machine removed all old values stored in variables. And it is wainting for you to start calculating.
Enter any operation
1[+]1 should give you 2.
If the keys do not answer when you press them and nothing shows on screen you the calculator may have to be repaired.
Hope it helps.
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
When I turn on my calculator, half the screen is blank. When I enter numbers, they show up after the blank side. Basically, the left side of my screen stopped working, and it has nothing to do with...
Since I do not see the kind of screen you have, I surmise (maybe wrongly) that the split screen is activated.
Press [MODE]. Use [DownArrow] to scroll to where is says Full Horiz G-T. Highlight FULL and [ENTER] Then [2nd][QUIT].
If that does not solve the problem
[2nd][MEM] [7:Reset][2:defaults][2:Reset]
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-83 Plus Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
Won't print/feed
Try removing the batteries in addition to reseting the calculator.
Oct 12, 2007 | Canon P23-DH Calculator
Canon P27-DH 12 Digit Mini Desktop Printing Calculator Logo
708 people viewed this question
Clive
Clive
old marine
old marine
