I have tried removing the batteries from the remote and changing the batteries. I have tried unplugging and the replugging the tv power source. I have tried going through the menu. It is very annoying.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Menu keeps popping up!
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
SOURCE: A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
SOURCE: My LG tv has a mind o its own. First off, the tv
The tv PCB board manual contol buttons board is shorted,that why u have ramdoom screen menu pop up.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tv manual PCB control board for the replacement.
