Question about HP Deskjet 3845 InkJet Printer
How can I locate ink supply warning on windows vista
    Scholar:
  • 104 Answers
You need to go to control panel and then click on printers and faxes. then give a right click on your computer and select properties. then select printing preferences and then go to maintenance tab there you will be able to find the ink levels of your printer
Posted on Jul 14, 2009
Please can you tell me where the waste ink absorbers are in a canon pixma mg6450 and how to remove them. Thanks
Hi. I guess your printer is showing the ink adsorber are full warning.
The ink adsorbers are located in the bottom of the printer . Practically you need to disassembly and remove all mechanism. The process is complicated even to technicians.
I recommend to you to get a new printer
Jun 22, 2017 | Canon Office Equipment & Supplies
Vista incompatability ?
Try to un-install the driver first of the printer, after you do this Install again the printer driver..
Thank you
Jun 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
My new epson p 50 don't work with new refill ink rechargable, the printer say don't recognize the ink, but the seller tell me there no problems of compatibility... why my printer don't work???
  1. With the ink cartridge holder in the ink cartridge replacement position, lift the lids on the cartridges but do not take them out.
    • If the cartridge holder is not in the ink cartridge replacement position, press and hold the maintenance_button.gif Maintenance/ fonte1.gif ink cartridge replacement/ cleaning_button-also-ink_cart_replacement.gif cleaning button (depending on your printer model) until the holder moves out.
  2. Check the yellow tag/flap has been removed from the top of the cartridges.
  3. Push down firmly on each cartridge to make sure it is clicked into place.
  4. Close the lids down gently but firmly so they click into place. Be careful not to touch the cartridge sensor.
  5. Press the maintenance_button.gif Maintenance/ fonte1.gif ink cartridge replacement/ cleaning_button-also-ink_cart_replacement.gif cleaning button on the panel to move the carriage back to the right hand side and start the ink charging process.
    • This process takes about one and a half minutes to complete.
    • When ink charging is finished, the print head returns to its home position on the far right, under the plastic casing. The dx4400onbutton.jpg power light stops flashing and remains on, and the black%20ink%20icon.jpg error light goes out.
  6. If the black%20ink%20icon.jpg error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly. getfile.aspx?rid=110
  7. If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning when the cartridges are genuine, perform a full uninstall and reinstall of the printer driver, using the latest driver from the Drivers & Software section of the Epson Support website. For help with this step, see one of the following Related Articles:
  8. If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below:
    1. Power the printer OFF.
    2. Disconnect the power lead for 60 seconds.
    3. Reconnect the power lead. Do not power the printer on yet.
    4. Perform a printer operation check.
Dec 12, 2010 | Epson Office Equipment & Supplies
HP3550 PROBLEM
I eventually discovered that the blinking was simply caused by the printer running out of ink. I intially dismissed this as a possibility because Windows always used to warn us when the ink was getting low. However, I presume that we no longer get those warnings now that we're running on Vista rather than XP - a compatibility issue I guess.
Aug 12, 2008 | HP DeskJet 3550 InkJet Printer
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Jul 11, 2008 | Epson RX595 Photo All-In-One Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
Vista cannot regocnise my rx600
5. Try printing.
*NOTE:
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
HP Deskjet 3845 InkJet Printer Logo
121 people viewed this question
Seeker5211
Seeker5211
