Dell 4600
When editing the BIOS if you go into the BOOT ORDER menu, it is possible that the network card is not showing as an option. In order to get this option to display, go into the "integrated devices (legacyselect options)" and then select the network interface controller. Edit that even if it is On and change it to On w/PXE. After saving the changes to the BIOS, you need to power the computer off then on and then go into BIOS again, and the "integrated NIC" option should be available in the BOOT ORDER menu. Set this to be the first boot device in order to use PXE.
