Question about HP Photosmart C4280 Aio Printer
I have been advised to not print on the back side of paper that has been printed. It is "not good" for the Printer. Is this true?
  • alwrth Jul 15, 2009
    If this is true, does it apply to printers designed to do duplex printing?
    If the first printing has been done days ago, can the ink still damage the printer's ink heads?
  • 39 Answers
It is true, the ink of the previous print CAN damage the printer's ink heads.
Posted on Jul 14, 2009
Print on left side of paper lighter than right side
Are you using a photo paper designed for printing on both sides? Most one sided photo paper is only meant to be printed on one side, and the other side is not designed to show true colors.
May 02, 2013 | Dell 1320c Laser Printer
Is there any way to get ink to dry on the wrong side of photo glossy paper? I am trying to print my own postcards on my Canon MG5220. Now from reading a forum here, it appears that because I made the...
Hi Robyn
PRINTING ON REVERSE SIDE OF PHOTO PAPER
The only realistic choice here is for you to chalk this episode down to experience, buy some new photo paper of the correct type to produce your preferred outcome and then do another print run of the postcards.
I always advise, when printing on exotic papers and even when producing ink intensive printing on ordinary paper, to print a single test copy first and then study the result, rather than completing the entire print run in one go.
Because of the lack of absorbency on the reverse side of the paper you used, I would also recommend temporarily putting the printer settings back to regular paper and printing a test page, so the micro-nozzles on the print head are cleared of any excess ink. If the test page is not perfect, then also run your printer's Print Head Cleaning maintenance tool. Then reset the printer back to photo printing for another run at your postcards.
Good luck.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 01, 2011 | Canon Pixma MG5220 InkJet Printer
P2015d - Jams when printing double-sided as it pulls the sheet back into the printer for the backside print.
Check is there any paper particals jammed in duplex unit (RM1-4258-000), repalce roller face down(RL1-0527-000), if is difficulty to find out the part remove this roller files the surface of the tyre with sand paper fix it back. This activity advised for tec guys only.
Sep 23, 2011 | HP LaserJet P2015dn Printer
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
How can I print on both sides of paper?
Unless your printer has a "duplex" feature, you'll have to manually take the paper out, flip it over and put it back in to print on the other side.
Feb 26, 2010 | Canon Pixma MP500 All-In-One InkJet...
Re: Canon Pima MP500 Printer.Despite running cleaning settings for print head and rollers ectc,I am still getting a 1cm wide line of black ink through the length of the reverse side of printed pages....
On back side of printed paper?
It means that you have an ink in paper path, i would ques on registration roller (long black roller which you can see when you open the printer cover).
Try to print 20-30 white sheets or similar to get rid of stripes
Jan 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Printer says out of paper when the tray is loaded
1. Shut the printer down
2. disconnect the power cable and network cable if you have one
3. wait 5 minutes
4. put the cords back in
5. power the printer back up
Good Luck !!!!!
Jul 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How to print both sides in this printer if we use windows 2007
Sorry to inform you , this machine does not support duplex operation You can try printing pages 1,3,5,7 etc then place back in printer upside down and print 2,4,6,8 etc Hope this helps you
May 01, 2009 | HP Color LaserJet 5500 Printer
HP Photosmart C4280 Aio Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
