I refilled the ink cartridges on my Canon iP1700. The print screen says they are low on ink and the orange light blinks four times. I unpluged the printer as directed in my manual. ??? The orange light continues blinking even after reinserting the ink cartridges. It won't let me do any ink test patterns, cleaning cycles, etc. What now?
    Scholar:
  • 105 Answers
The refilled ink cartridges do not have the chip which comes charged from the company. It is suggestable if you can spend on the new ink cartridges, do it. or else you can buy from the market compatible ink cartridges which comes with pre charged chip on the cartridge. this chip when comes in contact to the printer carriage assembly where the circuit is located. the printer works fine without any errors
Posted on Jul 14, 2009
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Pixma iP1700 error message
see if reinstalling the printers drivers and print software, see if that helps it,
regards
Paul.
Feb 05, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
604
Oct 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
201 people viewed this question
k24674
jasbo
jasbo
