Question about True GDM-69 Refrigerator
Both lights went out at same time , replaced them still doesn't work .. Is it a Fuse ?? Where is the fuse box ?
  • True Master
  • 3,361 Answers
Bad ballast. Located in the frame work under the door.Take off the panel to access it.
Posted on Jul 14, 2009
Running lights on a 1998 ford Windstar not working
Are your turn signal still working ? In your fuse box, which can be under the hood for some fuses and relays, and under the drivers side dashboard, it can also be on the side of the dashboard on drivers side when you open the drivers door, look for a door on the dashboard and pull it so in your owners manual it will tell you what fuse it is, but the fuse box under the hood should have a diagram of the fuse box and which fuse or relay it is I have only ran into this once, were all the bulbs went bad at once, now there is a sense in most of these cars for day time lights, and if covered will not work, but the sense can be bad, or your head light switch could be bad to
Dec 04, 2013 | Ford Explorer Cars & Trucks
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Speedometer
Sounds like a wiring problem. The speedo is powered on the same circuit as the gauges, and the instrument lights are on the circuit with the tail lights but with a different fuse. So you are actually talking about 3 different circuits.
May 11, 2013 | 2000 Ford F250 Super Duty Crew Cabs
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
My passenger side power window was out for some time. We just lived with it. Then all the rest of the windows drivers, 2 vents, went out at the same time. Since we're getting ready to take this old...
Buy a 12 volt test light under $20.00. If you already have one its even better. attach the allagator clamp to ground ( metal part of car) close to your interior fuse box. with the key in the on position touch pointed side of light on the small metal area of fuse it should lite the light on both sides of the fuse in fuse box. If you test a fuse and it only has power on one side that fuse is bad and needs to be replaced. make sure you replace it with a fuse of the same value. Since I am not their to check I think the circut breaker you replaced may not be the circut powering the windows
Jul 02, 2011 | 1998 Ford Windstar
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
My brake lights just went out in my 2001 VW oassat could it be a fuse?
If both lights went out it could very well be the fuse, check the fuse box located below the dash and see if the fuse labeled taillight/brake light is blowen if so replace fuse and the lights should be working again.
Mar 14, 2010 | 2002 Volkswagen Passat
Parking light fuse
It should be fuse #36 (10 amp) in the box under dash. Its marked illum. lights. If it was blown and it blows again after you replace it you have a short somewhere in the circuit. P.S. your owners manual should give you fuse locations.
Jul 28, 2009 | 1996 Nissan Sentra
True GDM-69 Refrigerator Logo
296 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
