Question about Sport & Outdoor - Others
I have a 2005 FX, it has been in the water a couple of weeks - kept on a jet ski dry dock. It was running well all weekend then when I pushed it into the water it idled fine and pushed water through the back but when I tried to accelrate the RPM's would increase but there was no power and it vibrated substantially. I could barely get enough power to get it back on the dry dock. Any thoughts?
  • perrotta Jul 14, 2009
    I have proper flow, yamaha's have an outlet on the back pad tha shows water is flowing. Any other thoughts??
  • perrotta Jul 20, 2009
    there was something in the impeller - old piece of rope. thanks for the help
  • 6,982 Answers
A jet ski is basically just a big water pump with a seat. Make sure you have proper flow through both inlet and outlet for pump and that pump has not failed.
Posted on Jul 14, 2009
  • Richard Scordino Jul 14, 2009
    If rpm's are up, and pump is pumping, it has to move. You need to actually look at the inlet to make sure there isn't a partial obstruction, and if need be, do some checking into the pump to make sure it hasn't broken internally (Shaft , coupling or impeller). I generally don't work on these (rather be building a drag engine) but have often enough (when coerced by friends who have them) to know that if it don't pump, it don't move.
How to fix slt 780 fading speedometer
Fading as in can no longer read the gauge or fading as in the needle drops as the jet ski runs across the water even though same speed is being maintained?
Jul 19, 2014 | Clymer Polaris Jet Ski & Water Vehicles...
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
2010 Yamaha FX Crusier jet ski
sparks ? compressions 100psi or more ? water in fuel ? injecters clean ?
Jul 14, 2013 | Boating
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
Jet ski wont crank
test voltage at the starter while pushing start button. its also possible that the factory ignition kill is activated, try holding up the lanyard button and repeatadly hit the start button if the alarm is engaged then you should hear the starter barely kick every couple of seconds so then just unlock it. and last and certainly the most common, starter solenoid, they go bad all the time. be sure to check your fuses first though.
Aug 24, 2012 | Water Sport
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Sport & Outdoor - Others Logo
87 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
