Then tried to spin the shafts and it would not spin forward but it spin backwards
Hello Todd, thank you for your post!
From my understanding your Frigidaire washer made a loud noise then stopped working and you also smelled burning rubber. This could be a possible issue with your moto, belt, or pulley. I would recommend contacting a professional technician for proper diagnosis and repair. Since it could be anyone of these underlying issues a technician would be able to pinpoint the problem without multiple part purchases. A technician will have the appropriate tools needed to verify which component may need to be replaced. Hopefully this information is helpful to you. -Matt
SOURCE: washing machine smells like burning rubber!
sounds like you have a broken motor coupling while your down to the pump check for something jamming the pump here is the procedure First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
SOURCE: Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
SOURCE: Spin cycles doesn't work, tub full of water
i have a similiar problem, mines fills up with water, and the three orange lights start beeping when it suppose to be agitating. please help
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
