I have a UK bought rega planar 2 turntable. I tried to use it in the USA using a step up transformer and it runs fast. How can I fix this?
    Problem Solver:
  • 18 Answers
As far as I can see, this turntable uses a belt. I believe the motor is synchronous (12 vac), it is designed with a pulley for working at 50Hz. At 60Hz, it turns 20% too fast. It may be possible to change the pulley as it needs to have a smaller circumference. I think you should contact a Rega representative or the company directly in the UK (www.rega.co.uk)
Posted on Jul 17, 2009
Install record player cartridge
Two screws and a wiring connector is all.
Jul 14, 2017 | The Audio Players & Recorders
Is it possible to use this turntable from UK 220V 50Hz, in the US 110V 60Hz?
Go to Radio shack or other electronic places and buy the correct converter for it.
May 18, 2015 | Audio Players & Recorders
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
AIWA LX 70 TURNTABLE THE BELT THAT MOVES THE ARM TO THE RECORD IS BROKEN. WHERE CAN I BUY ANOTHER ONE, AND IS IT EASY TO FIT
Hi jun_tradjazz,
I have an LX 70. There are two drive belts. They are identical and of a standard size, ie., not specific to Aiwa, Quite few years ago these belts wore out on my deck. They became smooth and the pulley wheels began to slip. I was lucky that a local electronics shop in town (Belfast,NI) had spares and replaced them "off the shelf". Sadly they can't do that now.
There are specialist retailers on the net who provide all sorts of drive belts of this type. The trick is to find the spec! Perhaps, if you contact them, they might be able to match a new belt with one of the belts on your machine.
From memory, replacing the belts is fiddly, but not very difficult if you are patient and examine the mechanism carefully.
Although I now use a Rega Planar 3 with motor upgrade and a Rega Exact stylus , I still love the magic of the LX-100 and cannot bear to part with it. A beautiful piece of design with it's link to the Strathean Audio (a Belfast HI-fi company, now defuct) direct drive system that it employs.
Good luck with your search.
Pat Cree
Aug 11, 2011 | Aiwa PX-E860 Turntable
Hello i need some help,i have pioneer 800 mk2 cdj i buy from usa but im live in london so difirent pawer supply here i bought the converter but try connect and its not showing nothing maybe the problem...
You can have a fuse problem only in you plug it diectly to 240V, the UK voltage. Check that the converter is a step down transformer, 240 to 110 volts. The system should work with 110Volts. If everything is ok, then you blew the system´s powersupply with the 240Volts. that is difficult to solve.
Dec 08, 2010 | Pioneer CDJ-800MK2 Turntable
'phones engaged' no sound
Well,
My onkyo receiver was keep displaying "Phones Engaged" and no sound.
All I did was plugged in a phones plug and remove it and for the last 2 weeks there is no problem.
I just happened to have a phone plug (without the actual headphone or wires) and that seems to fix the problem.
Hope it will work you all of you as well.
Good luck.
May 26, 2008 | Onkyo TX-SR502 Receiver
USA to UK transformer
you need a step down voltage converter I bought one in USA for my american nintendo but they can easily be got here check out any large electrical outlet
Dec 25, 2007 | Nintendo DS Lite Console
Motherboard ID
Try running Belarc advisor to check the motherboard manufacturer.
Lots of companies use Intel chipsets
Nov 16, 2007 | Computers & Internet
USA to UK CDJ800
Unless you want to spend some serious money, a multi unit step down will run you about US$300 or so. If you buy 2 or 3 individual converter's, your looking at about US$40-70 for a good quality model. Besides, it's better this way. If one of the converter shorts, only 1 unit will be affected.
Oct 29, 2007 | Pioneer CDJ-800 Turntable
300 people viewed this question
 Grubhead
Grubhead
