Question about Toto Washlet S400 for Power Gravity Toilets - SW564T694
I had an electrical surge (lightning strike) that burned up the input board. Can I order parts or a new board
  • 297 Answers
No you can not,must replace!
Posted on Jul 14, 2009
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
I replaced the power board with one from shop jimmy but still get no power/stand-by light at all. i can heard a very quiet rhythmic clicking from what sound like the power board.
The power surge may have affected components other than those on the power board. Check for burned components and signs of scorching or breakage.
Mar 22, 2016 | Samsung PN51E450A1FXZA 51-INCH 720P SLIM...
I have a LED TV that was hit with a power surge caused by lightning.
Could be your household insurance would cover the damage.
Unless the lightning strike was very local to you, on your side of the local substation, the responsibility for the cost of repair or replacement could be the power company's.
Surges from lightning strikes aren't supposed to get past the electrical substation.
Old-fashioned valve tvs and radios sometimes survived huge surges on the powerline and even minor lightning strikes to the antenna but solid state semi-conductors and micro chips aren't very tolerant to overloads of any sort. These days a tv is not longer a tv in the conventional sense but like cars and radios should be considered as just another computer that is full of CMOS chips which are extremely sensitive to overloads and static discharges. Even the screen of your tv is made up of semi-conductors.
I would be very surprised if the set isn't a write-off.
Sep 04, 2015 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
What is the first thing to check after a power surge caused by a close by lightning strike?
See if everything works. Stereos & TV's are usually the first to go. Items with digital devices go next analogs after that & grounded devices last. A whole house surge suppressor costs about 50 bucks and is just a few wires to connect & at the very least wall adapter surge suppressors should be connected to everything.
Aug 03, 2015 | Refrigerators
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
LG 47LC7DF Power surge (lightning) blew out hdmi and rgb and pc inputs, still have antenna and av inputs working. Is this an expensive fix?
you will need a new main board, your set has several different variations. The cost of the replacement board can range from $100-$150 from reliable sources. If you decide to order a new board, you will need to find out the part # of your main board so that you are ordering the correct board.
Sep 03, 2012 | LG 47LC7DF 47 in. LCD HDTV
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Lightning Strike
Replace with new will need new main board (170 bucks) and modeum board, for best protection it needs a fax filter that protects power line and phone line, standard surge protecter only protects power line
Nov 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
Toto Washlet S400 for Power Gravity Toilets - SW564T694 Logo
158 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
