Question about Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring difficulties during hookup
Pump is 2 speed with three hard wires from motor. White..Red...Black. Sticker say factory set for 220. Is to connect to 110. No instructions available. Can it be wired to 110 and if so how?
    President:
  • Hayward Master
  • 1,378 Answers
The side of the motor will have a diagram showing how to connect the wires for common high and low speeds. There should also be a voltage selector device on near the terminals you connect your line wires to. Set that device to the 115 setting and you should be all set.
Posted on Jul 17, 2009
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
My power supply has 3 wires, red, black and white. Pump wiring diagram has 6 posts for 1 yel w/blk, 2 brown, 4 black, 5 orange white 6 yellow. There is no red. what goes where?
see side of motor check voltage between red and black should be 220 red and white 120 volt black and white 120 volt make sure wiring is still for 220 from factory black to L1 red to L2 white to ground make sure white in box goes to green bus
Aug 01, 2013 | Polaris Booster Pump and Motor 34 HP
Pentair Superflo 1 hp. two speed wiring help ??
pump runs 120 volt low speed need 2nd hot for high speed see side of motor
Aug 22, 2017 | Pool & Spa
Wiring a Polaris 280 booster pump motor
if connecting 120 volt see side panel for wiring change from 220 to 120 volt move brown and white wires then black to L1 white to L2 then green to ground or case
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
How do I connect wiring and do programming for P1353 timer for my 2 speed pool pump? Thanks,
P1353 is a very complicated for beginner.
Open following link for manual: P1353 starts on Page 25
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
Following steps are general introduction.
You can add a comment about specific steps.
1) Select timer voltage: see page 26 manual
http://waterheatertimer.org/images/P1353-voltage-selection-100.jpg
Timer can control 120V or 240V circuits.
P13553 default voltage for clock motor is 240V.
If circuit breaker that supplies power to timer is 240V, then no change is needed.
If circuit breaker that supplies power to timer is 120V, then change jumper on back of timer to 120.
Timer mechanism snaps out of box using thumb spring located top inside box.
2) Wiring
Open link to see general wiring for P1353:
http://waterheatertimer.org/images/P1353-timer-350.jpg
-Bare ground wires connect to green screw
-Line wires are power wires from circuit breaker.
For example Line wires are 240Volt, and there is 1 black wire and 1 white
Black connects to terminal 1
White connects to terminal 2
Add a jumper wire (short piece of same-gauge wire) from terminal 1 to terminal 3
Add a second jumper wire from terminal 3 to terminal 5
This will put power to clock motor and put power to switches
-Load wires go to 2-speed pump: see wiring diagram page 28
There are 3 Load wires for 2-speed pump: Usually these wires are: Black for speed-1, Red for speed-2, and White
Black speed-1 connects to terminal 6
Red speed-2 connects to terminal 4
White motor wire connects to terminal 2 to complete circuit to motor.
3) Programming.
-Manual shows specific programming starting on page 27.
Timer has 3 circuits. Each circuit is independent of other circuit, making this a 3-channel timer.
-Select different MODES when programming timer
Select MODE 2: circuit 1 and circuit 2 will never be ON at same time, which is intended for 2-speed pump operation.
-Programming steps start on page 30 where you select MODE 2
Actual programming steps are straightforward
-Add a comment if you have difficulties and I will answer.
Also contact Intermatic directly if you encounter a glitch:
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | RTO Intermatic T106M Timer Mechanism Only...
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Wiring diagram for flo-master 56 frame xp2. I have a new pump that was improperly wired from the factory.It is a two speed pump only running one speed. If I knew where the factory wiring should be...
The side of the motor will have a wiring diagram for how to connect the common, low and high speed leads. Your wire harness should have a white (common), black (usually low), red (usually high) and green (ground) wire. If high and low are backwards, switch the black and red leads.
Nov 23, 2009 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I need to know how to wire 110 to 220 on a hayward sp-1605-z1 pump motor
The Hayward superpump is factory set at 220.
If you need to convert it to 110, all you need to do is take a screwdriver and remove the cap on the back of the motor. There are three prongs in the motor and a black jumper. The jumper connection needs to be disconnected and moved from The top and middle postion prongs, to the middle and lower prong. The ground wire (green) still connects to the same spot (usually a green bolt grounding lug). If using a Haward SPX1250wa (110 Cord) connect it to the pump Black wire to black connector/White to white. The Hayward cord comes with pre-attached terminal connections that makes it easy to do.
Once the cap is re-attached you should be good to go.
Oct 08, 2009 | Plumbing
The pump motor is a two speed 1.5 h.p.. It was factory set for 240 and I had only 110. Technician said we could eliminate one wire and this would accomplish the switch. The motor continually shuts on and...
Your three wire system was 115V? I assume then it was Line, neutral, and ground and you would hook the Line and neutral to the motor line posts and the ground to the ground post.
You also need to be sure to reset the motor from the 230 volt to the 115 volt setting to match the line voltage you are supplying.
Jul 13, 2009 | Hayward 1.5 Hp Northstar High Performance...
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Hayward SUPERPUMP 2.0 HP, 115/230V Logo
403 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
