Question about ASUS Eee PC 900 Notebook
How long does the battery need to charge before I can turn on the unit for the first time
  • ASUS Master
  • 4,806 Answers
Its recommended that you use the laptop straight away to run the battery out, then you can charge it and it will hold 100% charge thereafter as batteries have an in built memory.
Regards.
Posted on Jul 14, 2009
    Genius:
  • 1,847 Answers
Hi Donna,
Usually the batteries are completely charged from the factory itself A 6 cell laptop battery will take 8hr to charge completely.
Also check the manual for more detail.
Thanks for using fixya
Kevin
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Iriver mp3 player aa battery
Are you all sure the battery is fully charged? a lot of time I forget to shut my player off and run the battery dry. Should this not be the case then try the reset. If rest is not working try plugging into you pc if the unit shows it should be charging. You can reformat your unit Problem is you have to re-add your music. To reformat go to my computer right click your device and select format. Now unhook from pc and turn on unit. Should this fail them you may need to check for an update to the firmware. Otherwise if not under warranty still ,time for a new unit.
Apr 26, 2014 | iRiver H10 MP3 Player
Battery will not charge
Follow these steps if the Kindle battery is not charging:
  1. Connect Kindle to a different outlet.
  2. Verify the charge light at the base of the Kindle is on.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on? Contact Customer Service.
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact customer service for in-warranty options.
Follow these steps if the Kindle Battery is not holding a charge:
  1. Turn wireless off and fully charge your Kindle.
  2. With wireless turned off, Kindle battery life should be:
    At least 7 days
  3. If battery lasts less than the time frame given above, contact customer service.
If none of this helps, or you need to contact Customer Service here are the numbers:
In the United States: 1-866-321-8851 Outside the United States: 1-206-266-0927
Thank you.
Mar 03, 2011 | Amazon Kindle Wireless Reading Device
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
ZHow do I charge battery (new user)
just plug in your adapter that came with the unit.....leave it for the recommended time for charging and there you go.....if you don't have an adapter...you'll need to find out the required power that it needs and then purchase an adapter that will supply the necessary power....and also of course, the plug must also fit the receptacle on the back of your unit...with the correct polarity......good luck
silvio
Jul 08, 2009 | Dell Latitude C640 Notebook
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Charging Black and Decker Simple Start
okay people... this is a long one, but I just did it for two units that were having this problem and it worked both times.
The problem is the unit sat on the shelf and doesn't have enough power to operate its charging cycle.
Take an extension cord and plug in the outlet charger while you also plug it into your cigarette lighter... now attempt to charge it (you will hear the familiar alarm). Now, turn on the LED light... after a short time, turn off the light and the unit will begin to charge regularly. You can then use one of the chargers to finish the job.
By doing this you are providing plenty of power to the battery while the light drains it at a slower rate... kinda forcing the battery to condition/cycle; it's just allowing the battery to take the charge. Hope this helps.
Apr 28, 2009 | Black & Decker Simple Start Car to Car...
Need Help
Press the middle key and menu key at the same time until the apple screen comes on. This will reset your settings but usually when my iPod does something funky like that I just do that and it's fine. If that doesn't work, contact your local Apple store.
May 02, 2008 | Apple iPod nano
Charging Problem
Hi, Does the unit run off of the battery? Also, try running the unit without the battery. This tells us several things. Nice unit; I'm working on a similar one now. good luck Harvester3
Aug 18, 2007 | HP nx9110 Notebook
ASUS Eee PC 900 Notebook Logo
601 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
