Question about GE GSH25JFR Side by Side Refrigerator
The lines inside my refrigerator freeze up with ice buildup
The lines inside my refrigerator that lead to the freezer get heavy ice buildup around them, anyway to stop this?
  • GE Master
  • 3,361 Answers
Replace the defrost heater and defrost thermostat in the freezer section. They are located behind the freezer panel.
Posted on Jul 14, 2009
Model acd2234hrs amana is getting a lot of ice build up through outn the freezer all food in freezer has layer of ice on it
Check that the fan is running at the back of the freezer section. If it isn't, the freezer will continue to get colder but as the air is not moving around the cabinet, you get areas of ice buildup. The fan is usually at the top of the back panel, With the fridge unplugged, remove the panel in front of the fan motor. You can otherwise check if the fan is running by pressing the door switch whilst the freezer door is open. If the fridge is running, when you press the switch, the light should go out and the fan should start.
Nov 08, 2013 | Amana ACD2234HRS Side by Side Refrigerator
I have a GE side-by-side with ice and water through the door. The ice bin defrosts from time to time causing the ice to re-freeze in a clump once the temperature gets back to normal in the freezer. I...
Have you had a dispenser flapper replaced..if its not sealing (closed) properly it will lead to frost buildup in the location described..
You can check that by looking into ice chute form inside the freezer door and see if any light shines through
Jul 01, 2017 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Sometimes water comes out everywhere all over the floorand on the inside, now everything freezes inside the firdge
behind the freezer inner wall is a tube that leads down to a pan under your refrigerator it is blocked: remove the wall; remove the ice buildup on the evaporator coils then using a funnel pour hot water through the tube to the pan. be sure to empty the pan when you are done
Sep 05, 2009 | Whirlpool Freezers
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
My freezer is buzzing- loudly!
Sounds like ice buildup around the fan that's inside the freezer.  My lousy GE 3-door did that when the bottom freezer didn't get completely closed overnight, and everything behind the back panel, where the coils are froze up like an iceberg.  I had to take the back panel off and melt it with a hair dryer.
See if you see any abnormal ice buildup, or if the refrig compartment is getting warm.  That's usually a result of ice buildup.   Another cause is a failure in the defrost cycle.  It will freeze up after a couple days. This would usually be the defrost timer.
Oct 23, 2007 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
328 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
