Question about Panasonic DMR-EH65 DVD Recorder/HDD Recorder
When playing a recorded program from the harddisk the program stops every now and then for about 2 seconds and then continues. Formatting the disk didn't help. Any suggestions?
  • keeskoop Jul 16, 2009
    Thanks for the reply. This didn't help. I also initilised the recorder.
    It feels like a harddisk problem. Is there a way to do a full format? The format in the menu does only a quick-format.
    About the problem: Older recordings didn't have any problems. Only recordings of the last few weeks do pause during playback every now and then. The playback stops for 2 or 3 seconds and then jumps further. When the same recording is played again the problem occurs at the exact same spot.
Try turning everything off and unplugging from wall for 60 seconds and then retry. check surface is steady and that any air vents from device are unobstructed. check connection points the cable may not a bit loose.
Posted on Jul 14, 2009
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
Sep 21, 2010 | RCA M4204 MP3 Player
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
I am using Transcend 320GB external harddisk, file name "b12f74d84bc31b0b92c7" was observed, in that subfolder update is there. unable to delete that folder PLZ help me.
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
May 17, 2009 | iLO (2 GB) MP3 Player
Sanyo DVD recoder doesn't play if I let record run to end of disk
most dvd recorders have setting to finalize at the end of a timer generated recording, or to fianalize when the disc reaches the end and runs out of room, check for one or both of these settings in the setup menu of the recorder
Mar 31, 2009 | Sanyo DRW-500 DVD Recorder
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Toshiba A55 S1064
Sounds like either 1) bad disk or 2) bad motherboard. Replacing the harddrive and restoring using the restore cd is valid and will work as long as the disk is as large or larger than your current harddisk - Fortunately it is also the cheaper of the two options.
You may lose access to the free space on a larger harddisk as the restore cd may restore the old partition information as well as the data.
May 01, 2008 | Toshiba TOS TECRA 8/2.0 40GB 128MB XPT...
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Feb 03, 2008 | Panasonic DMR-ES20EG DVD Recorder
Disk reading
2 questions her 2 problems 2 answers. 1.Recording The machine is probably fussy about the type and brand of blank disk it will work with. Check your manual and sample several brands 2. Playing the burned disk you wish play if from another device has to be finalized in the burner machine.
Jul 30, 2007 | Sony RDR-GX315 DVD Recorder
Panasonic DMR-EH65 DVD Recorder/HDD Recorder Logo
176 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
