Question about Samsung SF-430 InkJet Printer
Windows XP does not list Samsung sf430 in its printer installation program. I need to find a Samsung model which is compatible. I think that the Samsung is out of date. What model can I install which will work for the sf430?
SOURCE: Samsung ML-2510 Installation Problem Windows Vista Home Premium
wellcome in fixya .com
please click on this link where u can find the driver of samsung ml-2519 for vista
Posted on Jul 29, 2009
  • 468 Answers
SOURCE: Samsung CLP-315 doesn't work with Windows Vista
http://www.samsung.com/sa_en/support/download/supportDown.do?group=printers&type=printers&subtype=colourlaser&model_nm=CLP-315&mType=&dType=D&vType=R&prd_ia_cd=06010200&disp_nm=CLP-315
Posted on Aug 13, 2009
SOURCE: installation samsung 4300 printer in ubuntu 8.10LTX
did you checked port settings on linux control panel and printer settings ?
Posted on Jan 07, 2010
SOURCE: smart thru 4 sacning program not work with windows vista.
DEAR SIR PLEASE GIVE SOLUTION PRINTER IS OK BUT SCANNER IS NOT WORKING
Posted on Jan 08, 2011
Looking for new printer driver for brother hl 1440 and windows 7
As per the printer manufacturer website, Brother Hl-1440 printer is not compatible with Windows 7.
http://www.brother-usa.com/Printer/ModelDisclaimer.aspx?Model=HL1440#SysReqs
However, you may download & try installing the XP drivers for the printer in Windows XP mode.
To install in compatibility mode:
1.a. Right click on the setup file of the driver.
b. Click Properties.
c. Click Compatibility tab.
d. Under compatibility mode, check mark "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop down list.
e. Click Apply and then click ok.
2. a. Under "Privilege level", click "Run this program as an administrator".
b. Click apply and then click ok.
3. Install the driver successfully and restart the computer for the changes to take effect.
Jun 07, 2012 | Brother HL 1440 Laser Printer
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
Running Windows 7 and can't use my Photosuite 7 Platinum
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, http://www.roxio.com/enu/products/allproducts.html?rTrack=m_pro_all . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
May 03, 2011 | Roxio PhotoSuite 7 Platinum for PC
I have a zebra p520i printer. My company recently upgraded to a windows 7 operating system. The old drivers v2.00 will not work with windows 7. Where do I find the proper drivers?
You could try here
http://www.bravofiles.com/download/P520i-USB-Card-Printer-8Jdu4kedAQ.html
This is a discontinued product so future drivers might be unlikely.
Mar 22, 2011 | Zebra 520I Printer
Windows 7 Version does not recognize the Lexmark X5470 All-In-One Inkjet Printer and I do not have the disk to install and it is not listed on the updated list......
There is not Windows 7 Driver for this printer, you'll need to install the driver through "Compatibility Mode" using the Windows XP or Windows Vista driver.
Download windows vista driver here (Click Here), open the link, click "Download" button, wait for few seconds and save it. After the download's completed, right-click the downloaded file, select "Properties" then on the "Properties" window, click "Compatibility", select "Run this program in compatibility mode for :" select "Windows Vista.." from the available options. Select "Turn of Advanced text services for this program", click "Apply" then "Ok". You'll be able to install the driver on your Windows 7 computer.
If this isn't possible, first extract the downloaded file and do the same steps mentioned above to the "Setup.exe" file.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Dec 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Windows xp problem
Hi
It seems you installed an outdated (16bit Program) for the ScanMaker 4. 16Bit applications/programs and generally DOS based (Windows 3.x and 95) and will not run properly from Windows XP.
First, check http://support.microtek.com/product_dtl_2.phtml?prod_id=23 and download and install Drivers and Plugins for Windows XP.
You may need new 3rd Party Scanner/Image Applications that work in Windows XP. However, if you still want to use the 16Bit application then you will need to run the program in 16Bit Compatibility Mode. To do this, right-click the program executable or shortcut, choose propertise from the drop-down menu, go to the Compatibility Tab and put a tick in "Run this program in compatibility mode for:" From the drop down menu, choose Windows 95 or 98 and apply.
Finally, check the the User's Guide or ReadMe file(s) (if you have it) for more info. Especially, check the recommended OS for the Applications.
I might be wrong, but i think ScanMaker 4 has a SCSI interface. If this is correct, then your laptop or port replica must have a SCSI port. NB: SCSI is not the same as Printer LPT Port.
Regards
Mike
Mar 23, 2008 | Computers & Internet
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
Multipass c555
Your cd probably only holds drivers for win98 and XP, i think your printer is not compatable with Vista, as i am unable to find yoiyr model no. on the canon website for vista drivers.
Mar 11, 2007 | Canon MultiPASS C555 InkJet Printer
Samsung SF-430 InkJet Printer Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
