Question about Whirlpool SB160PEE Gas Single Oven
How to unlock a whirlpool gold oven..i can open it..i cant start the oven to bae anything because it says its lock..i dnt know what to do.
  • Whirlpool Master
  • 3,361 Answers
You will have to replace the defective door latch switch. It is sending a false signal. Check with a Whirlpool authorized repair shop. Some of these were on a recall list.
Posted on Jul 14, 2009
Wall oven is showing locked. Door can open but cannot use other controls or cancel.
Self cleaning works by running the oven at full temp for a set period of time (1/2 hour should do, but don't leave it unattended) Will probably smell a bit as well when doing so.
Oct 05, 2014 | Whirlpool Gold 27" Single Electric Wall...
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I just moved into a new apartment, I can't find the user guide for the whirlpool gold gas oven, don't know how to operate the oven, none of the button works on the control panel, not even the start...
    You can go to whirpool.com then click on owner center and download a manual BUT YOU MUST HAVE COMPLETE model number which usually on inside of oven door or in storage drawer
    Jul 27, 2011 | Ovens
    My Whirlpool oven stopped heating. The control panel works/lights up. When you turn on the bake oven and start it appears to be working and you can feel the a motor running however neither of the elements...
    There is a thermal fuse mounted on the back of the oven that feeds power to both elements. This fuse has open up. The control panel gets power via a different path and still lights up.
    Jun 25, 2010 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool Gold oven is locked
    Had to switch it off at the breaker, wait for it to cool down, and switch the breaker back on. Then it unlocked. In the meantime, however, our french fries were completely incinerated, and the house filled with smoke.
    Jul 28, 2009 | Whirlpool SB160PEE Gas Single Oven
    How do you unlock the oven on a freestanding Accubake gas range/oven? Its a whirlpool gold.
    Take a wire coathanger and cut the long wire from the middle.
    Bend a small "U" shape on one end.
    Slide the "U" in from the left side of the oven door near the top center.
    Moving the wire back and forth slowwly to grasp the lock latch.
    When you feel the latch pull the wire firmly to the left to open the door.
    Then have the latch mechanism repaired.
    Mar 26, 2009 | Whirlpool Ovens
    Wont lock in self clean
    Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
    Oct 10, 2008 | Thermador C302U Electric Double Oven
    Oven wont work after self clean
    I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
    Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
    Whirlpool SB160PEE Gas Single Oven Logo
    1,197 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
