Question about Frigidaire FAC125P1A Window Air Conditioner
When i plug in my frigidaire fac125p1a the reset button trips immediately. won't turn on.
  • Ned C Cook
    Ned C Cook May 11, 2010
    Is the unit off when you plug it in?
  • 534 Answers
Compressor has gone to ground. In other words the reason the reset button trips is to prevent any electrical shock due to the compressor going bad. Only way to fix this is to have the compressor replaced
Posted on Jul 16, 2009
Keeps popping DMI immediately when it is plugged in its a refridgerator
Refrigerators need to be plugged into a regular outlet without anything else plugged in. DMI's, GFI's, or GFCI's are designed to trip at the slightest increase in amp draw. When the compressor turns on the outlet senses the spike and trips the curcuit. So to fix the fridge plug it into another outlet that is not part of the dmi circuit.
Nov 02, 2016 | Frigidaire Kitchen Ranges
Frigidaire fra18emu2 unit won't power on
Good Morning Marty, thank you for allowing me to assist you. Here are a few simple troubleshooting tips that may help you resolve this issue:
· First, confirm that the unit has power to it.
· Check the power cord connection to the wall outlet is secure.
· Make sure that the house circuit breaker has not tripped.
· Try testing the air conditioner again. Make sure the unit is turned off, Press the TEST button, you will notice a clicking noise as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
· The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. And the fan will continue to run during this time.
· If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 19, 2013 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire Fas297r2a has power but won't turn on
Hello Chris - Here are a few simple troubleshooting tips that may help you resolve this issue:
· Try testing the air conditioner. Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
Jul 15, 2013 | Frigidaire fas296r2a 28,500 btu heavy-duty...
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
How do you clear the service light on a S60 T5 2003. Please can you help.
Ensure all doors are closed.Turn ignition key to position 1.Press and hold reset button on a dashboard left hand side down/instrument panel/.Immediately turn ign.key to position 2.Keep reset button depresed until trip meter is reset to 0. NOTE:IF trip meter has already been reset.Hold reset button for 10-14 secondsuntil previous trip meter reading is shown.Press and hold reset button until trip meter is reset to 0 ;;;; Release a button within 4 secondsThere will be an audible signal When reset complete.
Nov 28, 2009 | Volvo S60 Cars & Trucks
I have a 2004 Volvo S60. How can I clear the "Time for Regular Service" message. I service my own car.
Close all doors.Turn ignition key to position 1.PRESS AND HOLD trip reset button,immediately turn ignition to position2,keep trip button held untill trip is reset to 0.A yellow warning light will show when it is time to release trip button.Release within 4seconds ,a bleep will be confirm reset.Before you start reset, do not reset trip,If trip has been reset to 0,turn ignition to position 2 hold reset for 10- 15 secs untill previous reading is shown,then start reset.
Oct 31, 2009 | 2005 Volvo S60
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Heating & Cooling Logo
513 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
