Question about Freezers
For a walk in beer cooler i installed a 1/2HP compreser 50 feet to the evp 2 fan fairly large,am i underpowerd or too far because i am getting freezing in the evp.any ans.
  • 614 Answers
No your are Ok . You may be to small on your unit. Check the charge you may be low. Make sure site glass is clear. Also I have had to install a dfrost time on several of my coolers. If you have one just set defrost for more or more often. Got to keep the beer cool. Rus
Posted on Jul 14, 2009
Compressor never comes on
I made video how to replace compressor on true air beer cooler, should be the same for most of prep tables and etc. Hope That helps someone. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Apr 01, 2014 | True Freezers
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Cooler don't keep temperatur at 36 to 38 evaporator frozzted
Your model number on the body of the freezer will have that. You can also get size of comp. and fan and rotation located on the pieces itself.
Feb 13, 2013 | Traulsen ARI332LP-FHS 208 - 3-Section...
Can the T-49F be converted from freezer to refrigerator?
Anything is possible so Yes... Although I wouldnt recommend it. The price to have a qualified technician do the job would reach very close to the cost of a new reach-in cooler and it could put a bit of a burden on the compressor. You are better off selling the freezer and purchasing a cooler with the money from the sale. It would involve one of two fairly large scale jobs. 1. The recovery of the refrigerant and installation of a CPR (Crankcase Pressure Regulator) with some wiring changes and adjustments... Or 2. The replacement of the compressor and capillary tubing.
Dec 26, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Commercial walk in freezer door damaged needs repair or replace?
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Nov 14, 2009 | Freezers
How long should a Coldtech 3 door commercial freezer take to get to optimum temperature? Should fyou feel heat on the exterior?
I tell customers to plan on a full 24 hours to get to optimum temp. And yes, there will be heat on the exterior.
Jun 14, 2009 | GE 13.7 cu. ft. General Electric Upright...
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
How far can the condensor be located away from ice machine
Their web site has all your answers. Their tech support line is worth the wait. 1-800-233-1940.
I usually don't exceed 25 feet. If it is a straight up install, that is, the remote is on a roof, you may have to install traps to ensure proper oil return to the compressor, Otherwise, it will lockup on ya.
Jan 16, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My 3 glass doors cooler
There are generally 2 reasons why this would happen. The defrost timer or heater has gone bad. Or, the fan is not working. Because you state that it runs all day long, I would think that the coils are now a block of ice and cannot cool. In any case, manually defrost it now. Turn off the power and use a hair drier on low (not hot) setting. This should fix the electrical cost for now. Then you can determine if the fan is running properly, or the defroster.
Apr 22, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Voltage to evaporator fan
Lots of things to look at. Let's get started.
Evap fans usually have some sort of fan delay, usually mechanical. These go bad fairly often. This could add resistance to the circuit.
You can have up to 1 Ohm of resistance through most mechanical t'stat devices. Anything over that, replace it. If you are getting 35 volts out of the board, it's probably the board. If you got voltage going in and not coming out, it's usually the board.
Mar 17, 2008 | Delfield 26.64 cu. ft. Commercial Freezer...
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
