Question about Mitsubishi WT-46807 46" Rear Projection Television
WT-46807 HD PRoblems
I try to plug in my xbox 360 via component 1 and the direct tv hd via DTV and nothing seems to work on Component 1 or anything else besides DTV for that matter? Any suggestions?
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Posted on Dec 26, 2007
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Does the Mitsubishi WT-46807 need a converter box to receive a HD signal?
Yes, this model only has one HD input--it is the one marked on the back of the set as DTV---you need to hook a box for HD to that input.
SD TECH
Oct 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Xbox 360 component cable resolution problems with tv
you can only play hd when you have all six plugs in not just the normal 3... i had this problem too
Jan 08, 2008 | Mitsubishi WD-73734 73" Television
Xbox 360
Hi there
As far as I'm aware the only way to get hd with the older boxes that don't have hdmi socket is through component unfortunately.
Microsoft have indeed pulled a fast one with this and cunningly released the elite for more profit.
I think the only difference betwen component and hdmi is that hdmi has built in audio in one wire where as with component you require seperate audio.
In short, No. HD only via component.
Hope this is of help
Dec 17, 2007 | Microsoft Xbox 360 Console
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
