Question about Samsung ML 2010 Laser Printer
Margin problem Although I have the correct settings on my margins in "page setup", whenever I print the text gets cut off on the right side.  The only solution I have is to manually increase the margin size in "page setup" before I print.  Is there something wrong with my printer or the software??  Thanks so much.
  • 1,113 Answers
Won't be the printer so I guess that leaves software or printer driver settings or the actual document setup.
Posted on Nov 17, 2007
  • Mark Wurden
    Mark Wurden Feb 29, 2016
    Are you sure it won't be the printer? I have this issue, and they've replaced the driver, checked all the settings, and all of this has had no effect. During their last attempt, they said it likely was the printer, and that it would need to be sent in for servicing.
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Messages from outlook express when printed cut off letters from left-hand margin.
The page setup for Outlook Express are controlled by the settings in
Internet Explorer. Use Page Setup in IE to change the margins and that
will fix your problem...
Good luck..
Oct 03, 2008 | Office Equipment & Supplies
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
I'm trying to print compact size directly from excel/word. What are the margins?
Step 1 Start Microsoft Excel and open an existing spreadsheet on which you would like to set the margins.
  • Step 2 Choose the "File" menu and click "Page Setup" to open the "Page Setup" dialog box. The "Page Setup" dialog box can be used to set up your page just how you would like it to appear.
  • Step 3 Click on the "Margins" tab at the top of the "Page Setup" dialog box to show the margins for the spreadsheet that you currently have option.
  • Step 4 Set the "Left," "Top," "Right," "Bottom," "Header" and "Footer" margins by clicking within the text box underneath each option to highlight the current margin setting.
  • Step 5 Type a new measurement for whichever margins you would like to change or use the arrows to move up and down throughout the measurements you can select for each option.
  • Step 6 Notice as you update each margin the preview in the center of the screen will change to reflect your new margin settings.
  • Step 7 Use your mouse to click the "OK" button to close the "Page Setup" dialog box and set the margins you have chosen for your current
  • Jul 07, 2009 | Computers & Internet
    Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
    I assume this error is occuring in Microsoft Word.
    1. Create a new document, with a full page of the label you are having trouble printing.
    2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
    3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
    4. Click the Fix button to have Word change the margins
      to match your printer. You should now see the Margins dialog with the new margin settings.
    5. Click OK.
    One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
    If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
    1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
    2. Select the entire table of labels ([Ctrl]+[A]).
    3. Right-click the table, and select Table Properties.
    4. Click the Text wrapping "Around" option, then the Positioning button.
    5. Change the Horizontal position to Center, Relative to Page.
      Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
    6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
    With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
    Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
    Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
    Always prints more to left than established margin
    Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
    Hope this helps. Bud
    Jan 08, 2009 | Lexmark Optra T610 Laser Printer
    Not printing whole page
    Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
    Dec 15, 2008 | Lexmark X2600 InkJet Printer
    Envelope margin error
    have you adjusted the page setup on your software?
    I'm assuming you're using Word to print a mail merge. yes?
    Check that the margins are setup properly in the "word document"
    Go undetr file, page setup, and confirm the envelope size is set properly.
    Check the page setup in the printing preferences.
    File, Print, Printing Preferences.
    The printer accepts whatever margins microsoft word tells it to use.
    Best wishes
    www.techvisitor.com
    Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
    Margin problem???
    I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
    Oct 24, 2007 | Dell 3100cn Laser Printer
    Paper margin problem in pagemaker application
    Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
    Jun 24, 2006 | HP Color LaserJet 2600n Printer
    Samsung ML 2010 Laser Printer Logo
    442 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
