Question about Whirlpool LSR8433K Top Load Washer
1990 MAytag Series 10 Washer - Fills with water, will not agitate
Tried the different cycles and none of them agitate. If I manually advance timer, will spin and pump out the water. Is this a timer problem? Don't think it is lid switch since it spins out.
Dave
  • 784 Answers
It is not a timer problem. This means the mechanism for the spin is still working and the agitation mechanism is not working.
The motor has 2 direction of rotations. One for agitation and the other is for spinning. Of course, there is a mechanism to assist this purpose. Your are lucky since it is easy to fix the agitaition mechanism than the spinning one.
If you take out the front pannel, you can access to the bottom of the shaft, The little white plastic is worn out. This one is the mechanism to activate the agitation. The rest you see are the brake, the clutch and the pulley to take care of the spinning mechanism, but you don't have to worry about them.
You just need to replace this white plastic part then you are good to go. Good luck.
Posted on Jul 14, 2009
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    It wont complete cycle and empty the water just hums for a while and then turns its self off
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
    The washing machinge is not completing the complete cycle
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Washer only works by manually advancing the dial.
    yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
    Dec 29, 2008 | Maytag SAV3710AWW Washer
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Ammana nav8805e
    If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
    Sep 02, 2008 | Amana NAV5800A Top Load Washer
    Whirlpool LSR8433K Top Load Washer Logo
    244 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
