I can't seem to pull the rope fast enough. I have to use all my energy to pull it fast enough for it to start. It has a new carb and runs well once it starts. 15 years ago, it used to start easily.
SOURCE: Wild Thing-(18")hard starting
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
SOURCE: Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
SOURCE: 04 crf450r hard starting
May be a decompression problem. What gear do you use when you pull it?
SOURCE: Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
SOURCE: HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
