Question about Back to Basics Smoothie Elite Work Top Blender
The black cog type gear on the bottom of the
The black cog type hard rubber gear on the bottom of the decanter is worn out
    Problem Solver:
  • 5 Answers
Give culinary parts unlimited a call @800 543 7549 to order a new part.they have everythinng
Posted on Jul 15, 2009
How it is done so that the axes of a blender or mixer, and especially the ones of the propeller of a submarine, under great pressure, not leak the liquid?
Good question.
Axles are generally left with cars and trucks.
That's because an axle transfers energy to more than one place by means of gears and cogs, like to a pair of driving wheels at right angles to the power direction..
What you refer to are spindles, prop shafts and other things.
For the sake of simplicity, the seals you speak of are made of rubber rings held by metal bands around the spindle squeezed very tight with oil trapped around the joint. That keeps the water out most of the time.
In bigger machines, the oil seal is often made from a tough kind of leather (true !) ...leather is a really good water proof material under heavy pressure and heat providing it's kept "wet" by oils or waters.
Blenders spindles tend to use rubber "O" rings around the shaft because there's not much pressure, it's enough to keep your milkshake from leaking into the blender.
Oct 17, 2016 | Blenders
Bl 5000 replace support ring
e-mail the manufactor maybe they have some.
Jan 31, 2013 | Black & Decker BL5000 ProBlend Work Top...
How do I remove the black rubber rotating bit on the Kitchen Aid Blender?
My clever hubby made a spanner (piece of metal with a slot cut into it) that fits round the spine under the plastic cog and then using pliers he could just unscrew the offending piece. Use masking tape to protect the top of the blender. Thanks for previous suggestions though as it saved going to a repairer and paying unnecessary costs. Cheers.
Feb 04, 2011 | KitchenAid KSB5 Ultra Power Work Top...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Oster 6700 Blender
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Oct 25, 2008 | Oster 6700 Work Top Blender
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
HB model 52735C type B35..intructions for blender pls
go to hamilton beach .com with model and serial no down load a book
Dec 31, 2007 | Blenders
How to install replacement part
You need the remove the old gray rubber knob. I did it in a barbaric way just hacking at it with scissors. Once you've removed all the rubber, you can use pliers to remove the remaining metal base. Once that's removed, place the new piece on the post and spin it on. Most important, spin clockwise to loosen, not counter clockwise like most items.
Oct 25, 2007 | Blenders
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Back to Basics Smoothie Elite Work Top Blender Logo
198 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
