Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength. CAD$12.81
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
Check your drain hose for kinks or clogs.
Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
Make sure that the water valves behind your washer are fully open.
Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
