Question about Gigabyte GA-8ID533 Motherboard
How to reset the bios p4 titan ga-8id533 motherboard
  • Gigabyte Master
  • 4,806 Answers
As the computer starts up hit the Del key, that will take you into the BIOS utility, once in the BIOS load optimized defaults, this will reset the BIOS configuration.
Failing this just remove the power cord from the back of the computer and take the motherboard battery out for 20 minutes, this will fully reset the BIOS so you will have to input the time and date.
Regards.
Posted on Jul 14, 2009
  • 59 Answers
Unplug the computer from power source. Unplug the battery from the motherboard. Look for for the closest jumber near the battery. Jumper have 2 position. Change position for 10 seconds, put it back to original position, put the battery back and the bios should be set to default
    Genius:
  • 1,847 Answers
Hi pizzaking196,
You should look for a jumper on the motherboard marked "Pass", "PWD", "BIOS", etc.
Typically you schould move the jumper over one pin, or it may have just two pins, and they need a shorting jumper on them.
Do that for a few seconds, and replace it as you found it. That should bring the BIOS default settings.
Let me know if you need further assistance
Thanks for using fixya
Kevin
Gigabyte motherboard wont recognize harddrive
resets the original bios settings then save the original settings
Apr 23, 2009 | 3Com Computers & Internet
Can't get into BIOS to turn on keyboard function
I would suggest either opening up your pc and reseting the bios, either by removing the the flat battery for a couple of mins, or if that doesn't work there may be a jumper or switch you can change that does this. I searched online but was unable to find any instructions for you.
You can either contact Gigabyte direct for instructions or try flashing your bios, both of which you can do from here:-
http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1398
Take note of the warnings when flashing the bios.
Jan 26, 2009 | Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limit in GA-8ID533 (Rev 1.1) motherboard
It supports all 4X AGP cards. The max you can get for 4X is 256MB. Nvidia GeForce series has some nice cards for these specs.
Jan 21, 2009 | Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limite in GA-8ID533 (Rev 1.1) motherboard?
If you have a 550w+ power supply you can run a Ati Radeon 3850 HD.
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
Audio/sound
For the Vista compatible sound drivers of a Realtek AC'97 as used in a Gigabyte GA-8ID533, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Gigabyte GA-8ST800 Motherboard
Motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
Mar 08, 2008 | Gigabyte GA-8ID533 Motherboard
PCI GA-8ID533 V1.1
there is no PCI lock on any retail boards. But there are IRQ sharings and conflicts. Set IRQ to auto, if not, then manualy and if so, then disable a few things, just to free up some IRQs. All depends on the board, best is to consult the manual for the IRQ sharing table and work with that. (disable one SERIAL, IDE port or USB port if you need an extra IRQ) Also check for onboard equivalent to the card you are adding, disable the onboard part...
Dec 27, 2006 | Gigabyte GA-8ID533 Motherboard
Gigabyte GA-8ID533 Motherboard Logo
603 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
