Question about HP LaserJet 4p Printer
The printer was printing several pages, then stopped, made a humming sound. I recieved teh error 13, and had to remove a sheet from the rear of the printer. Now when i hit the online button, there is a grinding sound, teh printer will not pick up a piece of paper, it seems to cycle twoce and tehn teh error 13 comes back. Any Ideas?
  • gbalzer Jul 14, 2009
    I had the fuser out and the gears seem to be fine. Is the film wrap suposed to be able to rotate without the gear turning?
    President:
  • 2,306 Answers
It sounds like the fuser gears are broken, that happens with paper jam sometimes from all the heat of the fuser. A new fuser will probably run around $100.00 for that machine.
Posted on Jul 14, 2009
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I tried to print a document from internet, there is a message on my monitor telling me that J4680 is printing, but the hardware (printer) is not doing anything. I did run the Self-Test and the printer...
go to the printer page right click on the printer icon that shows the name of your printer
and select as default porinter
if there is any docements in the que try and cancel the documents and see if it gets deleted
again select teh printer as online
and go to the properties page and try to print a test page from teh printer and it should print
and if it does not print disconnect and reconnect teh USB cable from the back of the printer
and try again to print a test page from the printer and this should resolved the problem and still if nothing happens let us know the status and we will help you further with the issue .
BEST OF LUCK
thanks
regards
Hamid
Feb 19, 2010 | HP J4680 Office Jet All-In-One Printer
Printing a full page 'background' (design) with no margins
No. The official minimum print margins are as follows
print margin specifications
Top (leading edge)
Bottom (trailing edge)1
Left
Right
Sheet Paper
U.S. letter
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. legal
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
U.S. executive
.07 in. (1.8
.46 in. (11.7
.25 in. (6.4
.25 in. (6.4
mm)
mm)
mm)
mm)
ISO A4
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
ISO A5
.07 in. (1.8
.46 in. (11.7
.13 in. (3.4
.13 in. (3.4
mm)
mm)
mm)
mm)
Sep 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp 4345 printer that is picking up multiple sheets from tray2
Frankly speaking, this problem exists and printer companies always have denied this. What I think from my experience that there is some engineering problem with all these printer, in the way paper is fed in.Still I give some solution which HP's site suggests. See if it works in your case:
Issue Multiple pages feed through the printer when printing. Solution If the printer is picking up multiple sheets of paper, follow the recommendations below:
  • Keep more than 10 sheets in the In tray.
  • Ensure media is not loaded too far and extending past the In tray.
  • Store all media in a dry, cool place. Humid climates will see this issue more often.
  • Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together.
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
  1. Remove the media from the In tray.
  2. Fan the edges, re-square the media, and reload the media properly into the In tray.
  3. Slide the paper width guide to the right until it stops at the edge of the media, then push the paper length guide towards the paper until it stops.
  4. NOTE: Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door. Remove the rear-access door (if applicable) and clean the internal rubber rollers with a soft lintfree cloth moistened with distilled water. Wait until the rubber rollers dry and replace the rear access door.
  5. Verify that the correct media size and type is selected in the printer settings along with the appropriate quality.
  6. If this issue still persists, try a different type of paper.
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=gb&dlc=en&docname=c00190540
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 26, 2009 | Office Equipment & Supplies
HP PRINTER
function addess protection fault errors when I try to print file and go through older version of Corel Draw Print setup menu. error says "Application Properties sheet pages may not work properly". Upon execution of print file, CP1518 prints a couple lines of gibirish on top of multiple pages. I have to cancel print job manually and CP1518 needs to be "cancel print job" several times before the printing of gibirish stops. I can print just fine from Adobe Illustrator, so I am thinking that is something within Corel Draw, perhaps I need a new driver so that it works with the CP1518.
Any suggestions appreciated. Thanks.
Sep 12, 2008 | Office Equipment & Supplies
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP LaserJet 4p Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
