Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
Want to control CISCO cable tv box, with Sony Remote
CISCO IPN4320 Cable box
RM-YD013 Sony Remote Control for a Sony XBR TV
What Sony remote control code can I use to control the cable box?
I went to Sony Web site and they do not list Cisco as a maker of a cable box. I have AT&T Uverse.
SOURCE: Verizon remote control code for Sony Bravia XBR
jesus christ people are retarded.
Posted on Jan 05, 2008
cezirkle
  • 27 Answers
SOURCE: sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Posted on Apr 03, 2008
mistersony
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
ron1235
  • 11 Answers
SOURCE: Remote control code
comcast is very helpful with this issue. have you called timearner?
ron
Posted on Nov 30, 2008
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Posted on Aug 28, 2009
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
WILL THE SONY RM Y195 CONTROL MY SHARP LC-19DV27 LCD TV???AND IF SO WHAT CODE DO I PUT IN THE REMOTE
According to Sony guide, this remote is not capable of controlling any TV other than Sony although it is capable of controlling multiple other components brands for cable boxes, satellite receivers and more.
Aug 09, 2010 | Sony RM-Y195 Remote Control
Can not get Close Caption to dispaly>
CC in the TV will only work while watching the TV's antenna or cable inputs; not the video inputs.
May 08, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Gain control of my Motorola cable box with a Sony RM-Y167 remote
Cable Converters (Set Top Boxes)
Director 0476
General Instrument 0476
Jerrold 0476
Motorola 0476, 1376
Pioneer 1877
Scientific Atlanta 1877
HOPE THIS WILL HELP YOU!!
Feb 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Got an older model sony xbr 36 tv. Wanna program it to work with mt time warner cable. How do i do it. Yhe TV is about 4 -5 yrears old.
Dec 21, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tv code
www.usersmanualguide.com/sony/remote_controls
Nov 04, 2007 | Sony RM-V310 Remote Control
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
1,759 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
