Question about Whirlpool GHW9100L Front Load Washer
The following day I have found water in the tub.Is it a bad valve? Also,it's quite a bit of water,more than 2 gallons.
  • 5,911 Answers
You either have a defective water inlet valve, or a defective pressure switch. An easy way to determine is to unplug the washer. If the washer stops filling, the pressure switch is faulty. If the washer continues to fill, you have an inlet valve problem.
To access both components, you simply remove the top panel of the washer. Locate the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then off. The water inlet valve will be located in the left rear of the washer, as viewed from the front (this is where the fill hoses connect to). The pressure switch will be located in the right rear of the washer, is round, usually brown in color and has several electrical connections.
The water inlet valve can become clogged with sediment causing the internal diaphragm of the valve to not seat properly. This can cause leak-by. If you live in an area that has hard water, or if you use well water this can be a common problem.
If you have to replace the valve, all you have to do is turn off the water supply and disconnect the fill hoses. Remove any dispenser hoses and the mounting screw(s) and the valve comes out. You can attempt to clean the valve by submerging it in a 50/50 solution of distilled vinegar and water to see if you can dissolve any sediment. Do not submerse the electrical connections, though. Allow to soak for 30 minutes, then rinse with hot water. This may or may not solve your problem. If you are going to go the route of removng the valve, it may be wise to simply replace it, rather that possibly repeating these steps twice. Just a thought...
The pressure switch comes out even easier. A couple of electrical connections and mounting screw(s) are the only thing that hold it in place.
Replacement parts can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com.
If you have any quesitons, please let me know. I hope you find this information helpful
PS An easy way to remove excess water from the tub (so, you don't flood your floor) is to remove the drain hose from the stand pipe at the wall. Then, using a wet/dry shop vac, pull a vacuum on the drain line. This will drain anything in the wash tub.
Posted on Aug 04, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
To resolve the issue you are facing with, you need to check the following things--
Verify the unit is leveled and not unbalanced. Next check pump drain system – this could indicate a failure to drain or washer is not draining properly. Then check operating pressure switch and pressure switch hose. After that you need to check flow meter operation and then the CCU which is the most important part in the washer.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 14, 2009
Water was pouring out the front of my machine. It was turned off and empty!
If you have hard water in your area, the valve could be stuck in the open position. Try running an empty cycle and see if it stops filling. Either way, you may want to follow manufacturers' instructions for de-liming. If this fails, the valve/solonoid may need to be replaced.
Best of luck.
Oct 09, 2014 | Maytag EPICz 3.7 cu. ft. Washer
Water capacity kawe860w
I don't have the number for you, but I can offer a method for measuring it. First, the next time you do laundry, set the water level switch to where you will use it for the dyeing task. With the lid open, but with no clothes inside, turn on the washing machine. Observe and note the level of the water when the machine stops filling. Measure the depth of the water. Add clothes and detergent and wash in the usual manner - you don't need to waste that water.
Next, pour four gallon jugs of water into a clean five-gallon pail, and mark the level in the pail (four gallons in the pail is much easier to handle than a brim-full five gallons). Pour that into the machine, and measure the depth. Put in another four gallons of water, and measure the depth again. If the bottom part of the agitator is covered by the first four gallons, you can can calculate from the increase in depth made by the second four gallons how many more gallons you need to get to the fill depth. (The bottom of the agitator takes up more volume per inch of depth than the center and top,) If the bottom of the agitator is not covered by the first four gallons, but is covered by the second four, then add a third four-gallon pour and measure the depth once more.
Here is an example measurement: water depth on chosen load size setting: 16 inches.
Depth on first four gallons: 2 1/2 inches (some of the water is under the bottom of the inner tub). The agitator bottom taper is almost covered, but not quite.
Depth on second four gallons: 7 inches. The water level is above the bottom section of the agitator, so from this point the water depth will increase by the same amount per gallon added.
Depth on the third four gallons: 11 inches. We can now see that from this point, adding four gallons makes the water level go up four inches, so to reach the 16 inch mark,we need five more gallons. The total will be 4+4+4+5 = 17 gallons.
For what it's worth, there's about 7.48 gallons per cubic foot. If your machine's outer tub holds an additional cubic foot of water, my example numbers may be roughly what you will get.
Apr 24, 2014 | KitchenAid KAWS850L Top Load Washer
Water boiling out of the pressure relief valve
1) Copy following links for troubleshoot resources:
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Problem indicates bad gas control valve thermostat.
The dial located on gas control, is part of the thermostat on gas water heater. Copper probe protrudes into water heater, and this probe contains the ECO energy cut off and thermostat. Thermostats get out of calibration, or they fail. Replacement should be done by experienced person, otherwise it is relatively simple using pdf link above.
Feb 17, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
There is water in the tub the next day or even week after a cycle has finihsed and the tub was totally drained. What's up?
You have a defective water valve. Fairly easy and inexpensive fix. Turn the water off until you have it repaired as it WILL overflow the machine! Mark
Oct 11, 2012 | Maytag Neptune MAH5500B Front Load Washer
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
http://waterheatertimer.org/Water-heater-leaking.html
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
Tub fills with water when not in use. Can't hear it running, but fills about a gallon overnight. I set it to spin and drain, it empties, next morning it has a gallon again.
your water solenoid valve is bad,unplug the unit and see if it still runs in about a gallon w/o the unit powered from the wall even if the unit is shut off,then you will know its a defective water valve
Oct 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher fills with water by its self.
yes you do the valve is very easy to replace located
at the bottom left of the d/w make sure to shut that power off
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
When the washer is off, even if the door is left open, the tub will fill with water and leak onto the floor.
sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Filling up with water
Jimbo, you are going to need a new inlet valve. This is very easy to change out. Remove the 3 torx screws in the back for the top. Slide it off toward the back. The valve will be on the inside top left. Two quick connect harnesses, a couple of hose clamps and your done. I don't have the part number on hand but you can find it on the tech sheet located behind the bottom panel. Three screws to take that off. Or you can go to repairclinic.com, enter your model number and hunt it down from there. Once you change the valve, your leaking problem will be over. Catriver.
Dec 19, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
