Question about Lexmark C510 Laser Printer
How do I fix an "Invalid Engine Code" problem with a Lexmark C510 printer? I read some where that I would have to flash it, but I can't find the firmware anywhere online. Does anyone have any ideas on where to get the firmware, and how to flash it?
  • 202 Answers
Go to http support lexmark dot com /printerfirmware
unsure of link posting here but you get there by googling it
then here are the codes
Authorization Keycode for C510 Engine Code = e140p
C510 Base Code = 891004
* Engine code version is 140P
* Base code version is 891.004
you need to follow the instructions on this it is a flash firmware upgrade, not a driver! hopefully you won't have a power outage while you try this.
Posted on Jul 14, 2009
T614 invalid engine code how to fix
Here's an article in the Lexmark website on The Printer Displays an 'Invalid Engine Code' Message. Just click on this link: http://bit.ly/aG7vrC. Read thoroughly the article first. Follow the instructions carefully.
But I would strongly suggest you contact Lexmark Technical Support for assistance, especially if there are options attached to the printer, to make sure all options will function properly.
Jul 06, 2010 | Lexmark Optra T614 Laser Printer
Lexmark C510 LCD shows underlined black boxes - not wrking
Hello you can try the following, try resetting the printer doing the following. Turn the printer off, then press and hold the arrow pointing left, the select button and the go (green) button. Hold down those three buttons at the same time and power the printer back on and wait if you see a message saying Restoring Factory Defaults. When that message appears you can let go the three buttons. If the same problem of the black boxes that flash appears then you might have a problem either with the Operator Panel or Engine Board. About the price that will run you to replace this parts I don't know.
Jan 28, 2010 | Lexmark C510 Laser Printer
Invalid engine code- how do I fix this
First try this link:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=invalid%20engine%20code&docid=BPD10
And if you do need to update the engine code, you can download it from this link. It also has instructions on how to update the code if your device is locally attached (via a USB cable).
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=code&docid=ENUS9414
If the device is on the network, download the engine file from the above link and follow instructions to update the code using the link below.
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:179:0:0&mode=DOCS&doctype=KB&term=code&docid=BPD35
Hope this helps.
Jun 01, 2009 | Lexmark Optra T612 Laser Printer
Invalid engine code
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Apr 23, 2009 | Lexmark Optra T614 Laser Printer
I have a error message on my Lexmark C510 printer that reads: Invalid Engine Code. The printer will not print. Any suggestions
Recycle the power a few times, if that doesn't work first reflash the engine firmware (you would need to contact Lexmark for that) failing that replace the engine board.
Apr 23, 2009 | Lexmark C510 Laser Printer
INVALID ENGINE CODE
you can get bat file from lexmark that will reprogram the nvram chip. the problem is when those errors start it because of a corrupted control code. the nvram has reached its read write max. there is also an eprom that goes bad. we replace them both
Feb 09, 2009 | Lexmark Optra T610 Laser Printer
Lexmark C510 - Printer will not print
Message:
Invalid Engine Code
What this message means:
The printer engine code has not been programmed or is not valid.
What you can do: [Not much]
Call for service.
See also: Calling for service
Dec 04, 2008 | Lexmark C510 Laser Printer
Lexmark C510 Code error: 995 Service Engine Error
May 06, 2008 | Lexmark C510 Laser Printer
Lexmark c510 re-installation problem
Reset the printer engine code.
You can falsh the printer with the USB flash utility form lexmark and reporgram the engine code.
The code is available for download at the lexmark website.
Oct 22, 2007 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
433 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
