Question about Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
My nintendo ds lite top screen goes in & out to a white blank screen when you open the console, help!
  • 19 Answers
Re: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Posted on Jan 01, 2008
0 characters
3 Points
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Nov 26, 2011 | Nintendo DS Lite Console
My DS Lite's top screen is blank white. Help.
a white screen can be due to two reasons 1. the screen is ruined which will cost you mush and 2. the display IC might have ruined which will not cost you mush .
Jul 07, 2010 | Nintendo DS Lite
My Action Replay is crashing.
if its one of the micro sd card action replay you can try to format it.make sure you get all of the data off for this take it back to the first time you got it from the store.
Aug 10, 2009 | Nintendo DS Lite Console
Nintendo Ds Lite Top Screen Problem(pls help:( )
It is probably the connectors connecting the screen to the bottom part where the CPU is. My portable Wii screen does the same thing. If you can live with it, your OK, but you might need a new DS. I recommend a DSi!
Jul 23, 2009 | Nintendo DS Lite Console
Ds top screen
Maybe you should take it to an electronics reapir centre, they work a lot of times. I have a similar problem, just so you know, my top screen is blank white, and it's getting me really **********. Hope your DS can be fixed!!^_^
Dec 13, 2008 | Nintendo DS Lite Console
Ds lite top screen problem
My ds has the same problem, except it stays white! but only because the cords on the left side of the ds (bust the part where the two light indicators are, power and charging, and slide the top screen to the right, then you should see the cords.) are not connected ore are lose from the central part of the ds. Ask nintendo or somebody who is a whire repairer to connect these wires.
Aug 07, 2008 | Nintendo DS Lite Console
Nintendo Ds Lite White Screen
Try cleaning the game. If you look at it in the light you may find it has some scratches or something. You see my brother has that! Love Tamsin
Mar 15, 2008 | Nintendo DS Lite Console
Ds lite
Looks like you left a loose wire or flexible ribbon cable, open the unit again and be sure the cables are well locked into the connectors, be sure the flexibles are in good conditions and over all check the screens or other metallic parts not to cause a short circuit.
Some metallic parts have electric tape isolations to avoid them to touch the circuit board and fry the DS for example when you press a button amd make pressure over the parts.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
682 people viewed this question
Top Nintendo Video Game Consoles Experts
Troy Gorman
Troy Gorman
Paul Layton
Level 1 Expert
Are you a Nintendo Video Game Console Expert? Answer questions, earn points and help others
