Question about Ricoh Office Equipment & Supplies
I have a Ricoh Aficio 1013 copier that has started to have an area of "ghost" printing in a narrow strip about 2" wide and 4" long on the lower left side of the copies that are being made. It appears to be the same printed characters on each page and is of varing contrast. The characters appear to be a portion of the text from approximately 2-inches above the shadowed characters.
  • Ricoh Expert
  • 393 Answers
Open the right door is there an image on the drum? (if not) It sounds though that your fuser has toner build up on it and is at end of life. These fusers are harder than most to rebuild so maybe a service call? -Carl
Posted on Jul 14, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
I have a problem in my ricoh aficio 1013, there is no prints on the paper coming out
try to check if the cam gear is still there,you can found it at the rear side of the pcu assy.
Sep 20, 2011 | Ricoh Aficio 150 Copier
Ricoh Aficio 1013 error code sc 544
Fusing low temperature error
Symptom: Detected fusing temperature
remained abnormally low for 1
second during fusing operation
(below 140°C) or during standby
mode
Possible Cause: Fusing thermistor defective
• PSU defective
• Bad connection between fuser and
machine
Dec 18, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Ricoh Aficio 1013f is duplicating print under each line. Happens on copying, printing and faxing. Have changed process drum unit twice in the last year, fuser unit and had unit cleaned. Was better for...
What type of environment is this copier in? Standard office, warehouse, etc. If the temperature in the area fluctuates a lot, that could have something to do with your problem. Usually ghosting problems like that originate in the fuser. Try increasing or decreasing the fuser temperature to see if that fixes the issue.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Even though my RICOH Aficio 1013 appears to be an ALL-IN-ONE, the ONLY function it now porforms that of a copier. What components do I need to add or install to get to function as a printer, scanner, &...
It would be cheaper to find a 1013spf meaning scan,print,fax. Finding all of the boards, wiring harness, ROM chips and control panel buttons needed to convert your machine would be pricy. Then you would need a service tech to install everything as well. You can find the "spf" versions used for less than $1,000 and you could get around $500 for yours.
Jan 15, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Ghosting
it is a drum moisture problem.protect your machine from moisture.keep your paper carefully.if the drum catridge crossed life (50000 copies) replace the same.
Dec 30, 2006 | Ricoh Aficio 1013 All-In-One Laser Printer
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
