Question about Motorola Mobility RAZR V3
Keypad lights up but screen stays Black??
My phone worked one minute and the next it didn't!!! I try turning it on and all that i got was a white screen then go black or my screen would come on for a split second then go to black.
My keypad lights up while i'm holding the button to turn on my phone and stays on but my screen stays black!!!! Even if i let go of the button to turn my phone on the keypad stays lit!!!
thanks!
Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
Jan 31, 2014 | Alcatel Tracfone A382 BIG EASY No-Contract...
Fix screen
screen still black / white it's not a screen problam .
it's belt problam
change your belt of cell who connect your slider to your keypad
that belt.
Jun 23, 2013 | UTStarcom Blitz Cell Phone
I was wondering how to fix it because I have some important stuff on it. When I try turn it on it just gos to a white screen and gets really dim then black
Change the LCD screen, it can be solved there is no image on the screen, but the power light stays on Dark display but still readable computer problems, this should help you:http://www.lcdinverters.net/
Oct 08, 2012 | Computers & Internet
My blackberry bold screen is very dark and I can't see what I am doing I have tried switching the phone off and factory reset with no sucess has anybody any idea what to try next?
try to go into settings, there should be a setting somewhere in there saying power saver or something, turn that off if its not already. otherwise, there must be something wrong with the screen lighting , like its blown or something.
Oct 30, 2010 | RIM BlackBerry Bold Smartphone
Samsung Tocco Lite says ''download'' on blank screen
I turned it off, then took the battery out for 5 minutes then put in back in and turned it back on, this should work, however for me it didn't so i turned it off and on again on doing this it went to the normal loading screen
Jan 27, 2010 | Samsung Tocco Ultra Cell Phone
Blank or White screen on new Motorola Krzr k1 cell phone
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone works for about a minute then goes black and dies
The keyboard cable is worn or broken, take it to a service center for replacement. The keyboard cable has a small magnetic switch that detects when the phone cover is open or closed. If the keyboard isn't working and the internal screen is blank, the phone detects that the cover was closed.
May 02, 2008 | Motorola Mobility RAZR V3
Blank Screens
try reflash the phone or replacing the lcd
Sep 12, 2007 | Motorola Mobility RAZR V3
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
123 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
