Question about Panasonic DP-8035 Grayscale Copier
How do you replace the staple cartridge - Panasonic DP-8035 Grayscale Copier
  • 100 Answers
Yep!
if you open the front door of the finisher unit, you will see some picture/drawing on how to replace staple cartridge.
Posted on Mar 22, 2010
How to add staples to copier
Oper the finisher door. Pull out the staple cartridge holder and replace the new staple cartridge. Follow detailed instructions at the side panel door ..
Jul 07, 2014 | Toshiba e-Studio 4540C Multifunction Color...
Wide black lines coming on paper while copying
Hello, One of 2 problems can cause this. 1. The toner cartridge is bad. 2. The Fusing unit is bad. Maint. kit if hasn't been replaced will work.
Apr 01, 2014 | Xerox WorkCentre 5632 Staple Cartridge...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Xerox Staple cartridge stuck
If the cartridge is stuck in the slide it is because there are still staples in the replaceable sleeve, if the whole slide is stuck in the finisher, you might open the panel over the staple unit and see if you have staples stuck that are causing you to not be able to remove the cartridge.
Oct 25, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
I have been trying to load the stapler but when I put the cartrage back into the unit it starts making a weird noise and the the screen still shows load staples so I do not know whether I am doing...
Remove the stapler cartridge and look on the clear plastic part of the cartridge. Do you see the arrow pointing towards the puncher side of the cartridge. The arrow of the replacement staples should line up. I've had customers put the staples in upside down before. The only problem is that you then have to take the staple cartridge apart to remove these staples and reuse them. . You just have to release the 4 clips at the bottom and carefully remove the piece. Be careful of the black arm that hangs down when the cartridge is held in the up position. When replacing the bottom back on, the orientation of this arm is important ( upside down or right side up) . This tells the copier that the staples are out. Hope this helps.
Jan 13, 2011 | Canon imageRUNNER 5570 Copier
HOW TO INSTALL STAPLES
Canon Image Runners have staple cartridges that can easily be installed. Just look at the area indicated on the lcd screen for location of where the staple cartridge is to be installed. Simply pull the used cartridge out with a gentle tug, then replace with the new one by simply pushing the cartridge in at a slight angle.
Hope this helps. :)
Sep 29, 2010 | Canon imageRUNNER 4570 Copier
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
The stapler is not working
Take a can of can air after you have removed the staples cartridge and blow out the socket that the staples fir into. Sometimes a jammed staple can stick in there and cause problems. Also if you can remove the bottom blade of staples out of the staple cartridge. Just raise that piece with the green on it and carefully remove just one blade.
If that does not work you most likely need a new stapler assembly and they could cost 2-$300. retail. If its under contract with a dealer this should be replaced for free.
Good Luck!
Jan 08, 2009 | Canon IMAGERUNNER 2230 Copier
Panasonic DP-8035 Grayscale Copier Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
