Question about Cameras
How can I photograph a total solar eclipse using the JVC GR-DVL520U (still shot and/or video? Will I need any attachments? My main concerns are manually varying the exposure and shutter speeds. 2 or 3 pieces of FULLY DEVELOPED black & white film work fine for sighting in at partial phase, & I have a tripod.
    Sniper:
  • 71 Answers
Hmmm... Even if it's fully developed, I wouldn't recommend you do this. You can get a number 14 welders glass from any welding supply company. Such filters usually have a thin layer of aluminum, chromium or silver deposited on their surfaces that attenuates ultraviolet, visible, and infrared energy. And even though the developed film has silver within it, it is not designed, optically, for photographic work. The welder's glass is reasonably priced and you ensure your eyes won't get damaged AND has good optical quality. After the fact is too late to change any damage done by inferior viewing devices.
If you're using a video camera with an LCD viewing screen, you don't need any protection. Exposure will be more than likely overexposed though and you may want to consider a 3-5 stop Neutral Density filter or a Number 14 welder's glass in front of the lens to cut down on the intensity of the light.
Posted on Jul 15, 2009
How can I use my telescope to safely view the solar eclipse?
Yes, you can, but with qualifications. You are evidently aware that you must never view the sun through the eyepiece of a scope without proper protective attachments being used. Blindness in that eye will be instant. Solar eclipse spectacles will not be sufficient protection as the light is focused powerfully at the eyepiece.
You can safely use a glass solar filter which attaches to the front of the scope. Tape it on for extra safety.
http://www.optcorp.com/astrozap-1506-glass-solar-filter-fa-73mm-79mm.html
You can attach a piece of solar-protective film to the front aperture of the scope. Do so securely.
http://www.optcorp.com/astrozap-solar-film-250mm-x-250mm-visual-az-1030.html
You should not ever use a solar viewing filter which attaches to the end of the eyepiece. There were a lot of these around until governments began banning them. The danger is that the concentrated heat of the solar image at that point will crack the filter, leaving your eye unprotected in an instant.
Mar 19, 2015 | Celestron Optics
Lens filter choice for photographing solar eclipse 20.03.15 south UK
A bit late but try here for solar filters www.wexphotographic.com
Mar 12, 2015 | Canon EOS 600D Rebel T3i Digital Camera
Hi! For Christmas (2010) I received a skywatcher telescope SK1141 EQ1 (D=114mm F=1000mm). I would like to be able to view the solar eclipse which is due to take place on the 3rd/4th January. I was...
Theoretically you can use eyepiece projection for solar images, by placing a screen opposite the eyepiece and focusing on it. Some telescopes come with an accessory attachment for this. However, there is the possibility that the eyepiece will be damaged by the heat, especially if it is one with cemented elements or if it has plastic parts.
Do NOT buy or attempt to use a solar filter to look at the Sun. If the filter cracks from the heat you will instantly lose your sight.
I'm not sure that I would bother with a telescope during an eclipse. You may not even be able to get it lined up and focussed in the short time available. At the last eclipse, I made a pinhole camera with a pinhole in a piece of foil placed in a blacked out window in a darkened room. The image on the hand held paper screen was good enough to photograph.
Dec 31, 2010 | Optics
How to take still photographs of solar eclipse
DO NOT look directly at a solar eclipse... You will do permanent damage to your eyes. If your camera has a "live view" LCD screen (Where you can look at the LCD while composing the image), use it to view the eclipse. DO NOT look at the eclipse through an SLR lens or other OPTICAL viewfinder unless you have the proper equipment in place to protect your eyes. You will typically want to use your full optical zoom on the camera to make the image and set the ISO setting to its' LOWEST possible setting. You will have TONS of light, so a low setting will reduce noise, giving you a much higher quality image. If you have exposure compensation on your camera, set it to underexpose by at least two full stops. Since the scene is so bright, it will fool a light meter, thus the need for this compensation. Also remember to use a tripod as well. When you use telephoto lenses, it magnifies shake introduced when you hand-hold a camera. If you're using an SLR camera, you will need a filter to view the eclipse through... here is a site that will give you GREAT detail on safely viewing a solar eclipse:
http://www.mreclipse.com/Special/filters.html
If you want to purchase one for your lens, go to any astronomy equipment sales site or telescope manufacturer. Hope this helps and good luck with the eclipse!
Jul 10, 2009 | Cameras
My computer does not recognise the device. What do
Did your camera come with an installation disk?
If so then install that or if windows ask you to install drivers do that.
If all else fails go to the manufactures site and look for any drivers or solutions there.
Apr 02, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
Jvc gr dvl520u - won't turn on or charge
Take out the battery and clean the gold connectors. I had the same problem for months and finally I tried this and it worked perfectly afterward.
Dec 19, 2008 | JVC Everio GZ-MG21 Camcorder
JVC-GR-D70AS
Just check this address: http://www.jvc-asia.com/sg/main/downloads.asp There will be a complete driver download for GR-D70 (all version - AS, US, etc.). The driver will include Decoder, USB driver, and many more inside. Good Luck!
Dec 27, 2006 | JVC Cybercam GR-D70 Mini DV Digital...
Capacity of the memory card
The models listed below are able to accept the memory cards up to 64MB without any problems (bigger sizes may work but are not verified at this time). If your camera is not on the list please contact JVC at 800 252 5722 2003 models GR-D70US GR-D90US GR-D91US GR-D200US GR-DX300US GR-DX75US GR-DX95US GR-DV500US GR-DV800US 2002 models GR-DVL520U GR-DVL522U GR-DVL720U GR-DVL725U GR-DVL820U GR-DVL822U GR-DVL920U GR-DVM76U GR-DVM96U 2001 models GR-DVL510U GR-DVL512U GR-DVL815U GR-DVL817U GR-DVL915U GR-DVM75U GR-DVP3U GR-DV2000U
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Cameras Logo
114 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
